Old 03-15-2006, 12:11 PM   #1
HotRod73
HotRod73's Avatar
Aftermarket Tach... Please Help!
I have a aftermarket tach i just bought for my 73... has points ignition... how do i hook it up..!!??
i know there are four wires... red is 12v.. where would that go... then black is ground...white is light, where does that go??? and the green is tach signal from engine... im not that mechanicaly inclined sorry can someone help??
HotRod73 is offline   Reply With Quote
Old 03-15-2006, 04:02 PM   #2
86 GMG
Re: Aftermarket Tach... Please Help!
the white can go under the dash to the headlight switch, green goes to the coil (i think) and the red will go to a power source that is hot after ignition switch is turned on a test light will be helpful. best of luck and if i am wrong someone outthere please assist in the answer to this b/c im not to familiar to points ignitions. oh and dont leave your ignition switch on for very long or you will be changing points as well.
square body trucks an addiction or an investment either way they consume all my extra time and money
86 GMG is offline   Reply With Quote
Old 03-15-2006, 04:07 PM   #3
swb85
On a budget like Fred Sanford
swb85's Avatar
Above post is correct--
red: switched 12v source (hot with key on)
white: headlight switch (12v for backlight)
black: ground
green: coil
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 03-16-2006, 10:11 AM   #4
HotRod73
HotRod73's Avatar
and since i have points i connect to the negative side of coil... correct?
Old 03-16-2006, 12:37 PM   #5
86 GMG
yes to the negative is correct sorry i didnt say that yesterday
