Old 03-24-2006, 08:34 AM   #1
TP from Cntl PA
TP from Cntl PA's Avatar
SBC to Inliner........Motor mounts?
I know it is possible to swap a 250 for a SBC without any trouble, what about going the other way? My K20 had a SBC in it(Now has a 454 with a Custom set of mounts going off the OE's)..................Could I drop one of my hot 250's in it with no trouble? I know it will fit, but I seem to recall the overall location being different V8 vs the little 6 from the factory.
I am just going to use the 250 for a time until I get a 292 built up.............Then I'll run that until I get ready to drop a 4-53 or 4-71 Detroit in it
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck
'71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel!
'69 3500 GMC 305V-6/4spd, Still under reconstruction..........
Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!!
TP from Cntl PA is offline   Reply With Quote
Old 03-24-2006, 01:58 PM   #2
sweet n rare67
Young truck fanatic
sweet n rare67's Avatar
Re: SBC to Inliner........Motor mounts?
The v8's and the I6's do sit in a different location...the I6 engine mounts bolt into the back two holes on the frame where as the v8's engine mounts bolt in the front two holes...The swap back shouldnt be a problem depending on what tranny crossmembers you have. I am not sure if this all apply's the same on a 4x4 but I believe that it would.... If you decide to do this and need the I6 Engine towers, just Let me know.
-Jake
'67 Chevy Longstep 2wd 350 w/4spd manual Muncie M21. My first project.
**Proud to be Valley Trash**
sweet n rare67 is offline   Reply With Quote
Old 03-24-2006, 03:46 PM   #3
TP from Cntl PA
-Jake
All our trucks(Well, my C-20 did too until I inlined it with a "Brand X" engine ) have inliners, parts trucks included............Other than this one I just bought, so I have everything I need..............Just wanted to know about location because I don't have one handy to compare.
Old 03-24-2006, 06:15 PM   #4
crazy longhorn
Fabricate till you "puke"
Your 4 wd , will accept the 250 inline on the stock small block eng stands the if they are still in the truck. The 2wd trucks, did mount the SB 3 1/2 " foward of the Inline spot, & roughly 2 1/2" foward from the factory BB spot. Best of luck on the swap..... L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 03-24-2006, 07:16 PM   #5
72armyswbtruck
72armyswbtruck's Avatar
All this motor swapping is making me
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 03-24-2006, 07:23 PM   #6
TP from Cntl PA
Don't blame me I had to have a Cummins in one.............Now I got one, and I want a Diesel in everyone I have because of it
But for the time being, a trusty dependable inliner will work
