Old 03-25-2006, 02:43 PM   #1
longhorn70gmc
longhorn70gmc's Avatar
Need help?
Hello all,
Been a while. I need some help? My engine was rebuilt by the previous owner and my block number is no longer stamped where it should be. I found the Bureau of Automotive repair/engine Identification tag.
Is there a way to decode this to discover what the original block number was? OR
Is there a place I can go to research it here on the web? I did go to the Bureau's site and it was not helpful.
Thanks for the help!!
Respectfully
Billy
1970 GMC Sierra Grande 402/TH400
(Longhorn)14 years and counting rebuild!
1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches
1970 Ford F250 Ranger 390 BB
2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires
Hub Cap Freak!
I need another truck like I need another hole in the head!
I'M IN THE MARKET...AS IT WERE!
longhorn70gmc is offline   Reply With Quote
Old 03-25-2006, 05:09 PM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Need help?
Everybody will tell you to look on the block on the left side rear of the engine and you will see a casting number. It will look like this ( 3970010 ) if it is still there . The numbers are about a 1/2 inch long and should be easy to see after you clean the crud off. When you can read them then go to this website,http://www.mortec.com/.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 03-27-2006, 12:01 AM   #3
longhorn70gmc
Re: Need help?
Thanks for the info. I thought the number was on the front only. I will look and get back to you.
Respectfully
Billy
Hub Cap Freak!
