Old 03-26-2006, 09:34 PM   #1
bad69bowtie
Active Member
BBC SWP Engine Pulley ID
Can someone help me identify the correct water pump pulleys for short water pump bigblock engines with and without power steering and air cond. I have a huge box of Chevy pulleys saved over the years and do not know which engines they fit. Any part numbers or pics would be appreciated. Thanks!
1969 C-10 short fleet 2wd. 400ci. w/350 Turbo.
'68 front clip and factory wood bed floor. 3"/5" coil drop.
1971 K-10 short fleet 4wd. Partial project truck.
1972 K-10 long fleet 4wd. Complete project truck.
bad69bowtie is offline   Reply With Quote
Old 03-27-2006, 12:32 AM   #2
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Re: BBC SWP Engine Pulley ID
All I can do is bump the thread for you. I put 86 small block pulleys on my big block...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 03-27-2006, 09:20 PM   #3
bad69bowtie
Active Member
I have heard that smallblock pulleys work. I just wanted to seperate my bigblock waterpump pulleys from the smallblock ones. Anybody else?
Old 03-27-2006, 10:36 PM   #4
Rod
If you posted the part numbers of some of the more lilkely pullies that you think are BB or SB...someone may be able to look them up in part book for you. Part numbers are stamped in the pulley.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
