Old 04-07-2006, 10:58 PM   #1
60 GMC
60 GMC's Avatar
Flywheel interchange
This might be a little off topic because my truck has a 76 engine at the moment but ill try here anyway. Does anybody know if a flywheel drilled for an 11 inch clutch off a 67 car 250 will bolt up to a 76 truck 250, im asking this because i have both the 11 inch flywheel on the 67 and the 10 inch flywheel on the 76 engine. Since i have to replace the the clutch disc and pressure plate it would be kind of stupid to put the 10 inch on there when i could have the 11 for the same price . Thanks
Aaron
60 GMC is offline   Reply With Quote
Old 04-07-2006, 11:22 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Flywheel interchange
The flywheels interchange freely between those two engines. Use which ever you want.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 04-07-2006, 11:26 PM   #3
60 GMC
60 GMC's Avatar
Sweet, I figured they would interchange, now would changing the flywheels affect the balance of the enigne?????
Old 04-08-2006, 06:53 AM   #4
Tx Firefighter
No affect on balance at all.
Old 04-08-2006, 11:06 AM   #5
60 GMC
60 GMC's Avatar
Thanks for the help Tx Firefighter.
