Old 04-05-2006, 07:06 AM   #1
68Stepbed
68Stepbed's Avatar
I need help! FAST!
I've locked my keys in my 86. How can I break into it? Someone help me, PLEASE.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 04-05-2006, 08:35 AM   #2
woodyjim
Re: I need help! FAST!
Do you have a slider in your back glass by any chance? If you do, you can snake a wire/coat hanger through your door seal over to the slider latch and pop it loose. Just a suggestion, I had to do it several times in a toyota I used to have. Got pretty good at it too. (Goes to show how many times I locked my keys in the truck). Good luck!!
Jim
woodyjim is offline   Reply With Quote
Old 04-05-2006, 08:41 AM   #3
86 GMG
you can slide a coat hanger through the top of the door and reach the lock knob put a u shape at the end of it to hook the knob good luck!
square body trucks an addiction or an investment either way they consume all my extra time and money
86 GMG is offline   Reply With Quote
Old 04-05-2006, 11:49 AM   #4
Russell
Professional Grade
Russell's Avatar
I personally drilled the vent window hinge rivet out, then reached in, lowered the window, and unlocked the door.
Fixing the window was a matter of putting a new rivet in
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 04-05-2006, 12:33 PM   #5
Eyegore
What Hump?
Eyegore's Avatar
Call AAA they break in for free if your a member.
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 04-05-2006, 12:38 PM   #6
68Stepbed
68Stepbed's Avatar
Well, it was a matter of getting to work on time, so I called a lockout service. He used two metal pieces with neat little bends, stuck them in under the vent window, opened it and rolled down the window.
Took him 15 seconds, then charged me $45! How do these people sleep at night?!
Matt
Old 04-05-2006, 12:43 PM   #7
bigblock73
yeller
bigblock73's Avatar
You wouldn't have had to pay $45 if you had a second set of keys..they cost about $2.
I make this a practice for everything I own with a lock on it.
bigblock73 is offline   Reply With Quote
Old 04-05-2006, 03:40 PM   #8
Prerunner1982
Prerunner1982's Avatar
not going to say how, but i can break into my truck in 30 sec or so.. havent had to lately... knock on wood!
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 04-05-2006, 03:46 PM   #9
f.monroe
f.monroe's Avatar
Your truck is a little too new , but the older trucks without an inside hood release can be opened by using the master cylinder lid retainer . Take it off and since it is rigid and already bent at a 90 deg . angle , it makes a good tool to reach inside the vent window with . Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 04-05-2006, 06:37 PM   #10
cliffsta
Stepsides RULE
cliffsta's Avatar
i KNEW there had to be a good thing about my outside hood release!
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 04-05-2006, 09:49 PM   #11
68Stepbed
68Stepbed's Avatar
Yeah, I know. I'm gonna get some copies and zip tie em in an indisposed area. I have an extra set to my 68, but I can't lock the keys in it. You have to use the key to lock the door.
Matt
Old 04-06-2006, 08:16 PM   #12
jermasaurus
jermasaurus's Avatar
I just keep a spare in my wallet. saved me plenty of times
-Jeremy
79 Jimmy slammed AKA James Down
jermasaurus is offline   Reply With Quote
Old 04-09-2006, 01:17 AM   #13
augie
Waiting for Paul to Open Safe
augie's Avatar
I know it's a little late, but since most of the latches on the wing windows wear out quickly you might try this next time. My latch no longer locks so if I put pressure on the window from the outside I can grab the knob which is on the outside and just spin the latch up. Even easier if you have some pliers. Then all you have to do is reach in roll the window down and your in. I had to wait 2hrs for AAA guy to come with his little tools and watch him do something similar (except he gouged the crap out of the window seal) the next time I locked myself out I figured hell, I can move that latch without the fancy tools. Never been locked out since.
augie is offline   Reply With Quote
