what happened to flint mi
does any one make replacement cab supports?
any one??? who has the best part ? thanks tom
71 swb 2wd fleet frame off in progress 72 4x4 blazer daily driver 70 olds cutlass s mint condition owned by a grandma 56 gmc 2wd project waitng 97 fiance mobile |
![]() Join Date: Jun 2002
Re: does any one make replacement cab supports?
EVERYONE has the front support, they are all similiar in fit, stay away from the slipons, unless you want to rework them every 3 years... It's more work to put the oem style in but it is worth it in the long run.
The blazers don't have a rear support like the trucks (regardless what LMC says...). They have a different system at the back support. I tend to buy from Tim Christian, but there are plenty of good vendors who can get you what you need. Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
