Old 06-15-2006, 09:32 AM   #1
60 GMC
60 GMC's Avatar
Gas filler modification
Ive been batting the idea around for a while,take the little flipper thing from a later GM gas filler and graft it into a 60-66 filler. So when i was cleaning out my dads stockpile of parts i cam across the filler from our Blazer. Asked him if i could have it and he said sure, so i started plotting how i was going to cut the the old filler to add the flipper in when i realized that,when trimmed a little bit,the flipper fits inside the the 60-66 filler.So i welded it in and this is what i got.It looks deep in the photo but its only set in there an inch.
60 GMC is offline   Reply With Quote
Old 06-15-2006, 11:35 AM   #2
60-66 Nut
Professional Beer Tester
Re: Gas filler modification
60 GMC, nice job. But if you don't mind me asking, why would you want to put one in there anyway?
60-66 Nut
60 Ford F100 Custom Cab
61 Apache Short Fleetside
64 C10 Short Stepside
65 C80 409 V8 5spd(X-Firetruck)
83 GMC 350 Olds Diesel
85 GMC Short Bed
86 GMC Short Bed
90 GMC R3500 Crew Cab
92 GMC 1500
60-66 Nut is offline   Reply With Quote
Old 06-16-2006, 10:15 AM   #3
60 GMC
60 GMC's Avatar
Well i wanted a way to keep gas from sloshing out when i go around corners or hit some bumps.
Old 06-16-2006, 12:38 PM   #4
60-66 Nut
Cool. Should help.
60-66 Nut
85 GMC Short Bed
86 GMC Short Bed
92 GMC 1500
Old 06-16-2006, 01:46 PM   #5
Mordachai
Fat Fendered Fleetside
Mordachai's Avatar
very nice, iirc, it also helps the newer autoshut off pumps stop before there's gas all the way up there.
definitly should help with any gas comming out, but a new rubber gasket would do the same...
71 GMC lwb
56 Big window swb
93 GMC Sonoma (dd)
radiused fiberglass fender project for 67-72
Mordachai is offline   Reply With Quote
Old 06-16-2006, 02:50 PM   #6
Fred T
Cantankerous Geezer
Fred T's Avatar
Best way to keep gas from sloshing out is to put on a new cap. The replacements you buy are non-vented, due to an EPA mandate.
Let me correct that. They are supposed to vent to allow air in, but not out.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 06-17-2006, 12:08 AM   #7
60 GMC
60 GMC's Avatar
Yeah the new cap is on its way and im replacing all the rubber in the fuel system,this was just a free modification that i was just wanting to tryout,
