Old 04-20-2002, 12:53 AM   #1
jostrans68
Jostrans68
jostrans68's Avatar
Post Brake Swap ?
Finished my swap 68 used 72 front donor. ? is I used the power booster that was on the truck for power drum and the pedal seems low I havent driven yet as I just finished exhaust. I saw some folks saying rod length different is that the booster rod to pedal or the one from the booster to Mcyl? I have the 72 booster just didnt really see a Diff so I used the one already mounted. I did use the Disc mcyl.. thanks in advance Keep Truckin'
68 c20 in progress 327 TH400 tach dash Disc Brakes and soon 3.90 rear gears.. have many new parts now just need the time..... Sound Familar
Tacoma Wa. The Rain capitol of the USA
[CGTW Member
former 67-72 now with a 96 silverado
jostrans68 is offline   Reply With Quote
Old 04-20-2002, 12:53 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
I tried puttin a disc booster on my drum truck...didn't work. I can only asume the same goes for your situation. Be carefull first time you put it in gear.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 04-20-2002, 07:21 PM   #3
1-PU70
1-PU70's Avatar
Post
The rod from the Master cyl to booster should not afect the hight of the pedal. The rod from the booster to the pedal should be adjustable.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 04-21-2002, 02:06 AM   #4
704x4
Post
mine took a few hours worth of adjusting to get it with no slop and enough pedal height.
the pedal will never come all the way up to the stopper on the dash with the booster, i looked at two other trucks that had power brakes originally and the pedal was just as low as mine is now
well worth it now that i go it right though!
don't forget to readjust the barke light switch or you might have a dead battery in the morning
70 3/4 ton 4x4
FOR SALE
Greene, IA
704x4 is offline   Reply With Quote
