![]() Join Date: Dec 2002
Does the rear pillar curve sit down outer floor
Sorry for another rust repair question but mine was so gone I couldn't tell
Based on the curved lip on the inner side of my rear pillar patch it sits down over the top of the outer floor section. ? is how Far is the spacing or right down on top. I searched all the rust sections but didn't see a pic Thanks |
Re: Does the rear pillar curve sit down outer floor
Can you get a picture of what you`re talking about?
Special K I will try. Do you see the K-20 in the Washington post over 40K invested Arizona truck $7700
PROJECT 7DEUCE
Pound get a pic and maybe we could help ya out..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Member #1049
Not sure if this will help but here is picture of a rear pillar and floor pan on one I just did.. the rear door pillar sits almost right on the floor pan..
Thanks Livrat its the door jamb side of the pic you took that i want. As soon as I can get my wife to unload her hundred pics on the digital camera I will post a pic. You can take the curve on the pillar which forms around the outer floor. You can put it right down on top of floor to 1/2 up and it looks like it belongs. Need to makesure its right because the lip is the frontside for the bolts that goes through inner rocker and into the small brace on the backside. This was the first thing I tore out many months ago and now its time for the final fitting before welding. I am almost replacing the entire Floor. About like Frenchblue's
![]() Join Date: Jun 2002
Here's a before shot... you can see there's a 1/8th to 1/4th gap there.
One thing to watch out for, the replacement I had was a bit longer from the curve to the bottom and once I had it welded in I found I had to cut and tweak the bottom of it to get the rocker panel to fit over it. I think the biggest concern here is getting everything bolted together once the new parts are in. Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
