Old 06-02-2006, 06:33 PM   #1
Wild83C10
Wild83C10's Avatar
Height Difference
So I lowered my truck years ago and never took any measurements before or after lowering it. I decided to swap some suspension components and lower it about an inch more. I took some measurements and saw that the passenger side sits about an inch higher in the front and the rear. I swapped the suspension components and it still sits an inch higher. Anyone else run into this problem? What might be causing it?
I also searched the forums and didn't see anything on this. If there are any old threads out there please point me to them. Thanks
I have replaced all of the bushings (body and suspension) and I have DJM tubular control arms, chopped springs, rear flipped with new welded perches with 1 inch lowering shackles, cal trac bars and I removed the helper spring.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 06-02-2006, 07:37 PM   #2
1badbowtie
Re: Height Difference
I do know that stock trucks aren't perfectly level, have you had your suspension aligned by a pro alignment shop?? I had this problem years ago when I put a 4/6" drop on my truck and it was unlevel a little bit, then I had it aligned to almost factory and it sat level. So this may or may not help.
ANDY
1badbowtie is offline   Reply With Quote
Old 06-02-2006, 10:42 PM   #3
Wild83C10
Wild83C10's Avatar
I had the front end aligned last time I lowered it. I guess I don't understand why an alignment would change the suspension height. How would you align the rear?
turbo=
Old 06-02-2006, 11:54 PM   #4
1badbowtie
You don't align the rear, but you can set your pinion angle correctly with shims.
Old 06-03-2006, 07:16 AM   #5
Wild83C10
Wild83C10's Avatar
Yeah I have checked my pinion angle and shimed it already.
turbo=
Old 06-03-2006, 09:13 AM   #6
bigblock73
yeller
bigblock73's Avatar
What suspension components did you swap?
Why were your perches re-welded?
"chopped springs"...did you cut your coils by hand? Are they stock cut coils?
bigblock73 is offline   Reply With Quote
Old 06-03-2006, 09:25 AM   #7
Wild83C10
Wild83C10's Avatar
I had western chassis lowering spindles and original springs that I cut. I now have DJM tubular control arms (3" lower arms) with the same original springs that I cut.
I had the rear flip kit but one night at the track I hooked up good and my rear twisted and ripped the original perches off. So I bought new perches and welded them to the underside of the rear axle tubes. I still have the original rear leaf springs without the helper leaf (now 4 leaves) and 1" lower shackles.
turbo=
