Old 06-02-2006, 06:49 PM   #1
T J Randall
Junior Member
Diamond Plate bed floor for a '68 short fleet...
Hi ya'll from Ponder, Tx. I'm considering this idea as an alternative 'cause going to wood at this time is cost prohibitive. The steel floor is trashed and I already picked up a steel floor front bed wall. Lookin' for some ideas and support from the membership as to the easiest way to go about this. Cardboard template, or use the old floor piece flipped over on the plate, etc.. Any suggestions, (please .. no cussin') will be appreciated.
T J Randall is offline   Reply With Quote
Old 06-02-2006, 06:58 PM   #2
Sweet72
Sweet72's Avatar
Re: Diamond Plate bed floor for a '68 short fleet...
Sounds like a good plan. Definitely use the old bed floor as a template. Steel or aluminum? Check the cross sills for rust holes.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 06-02-2006, 07:05 PM   #3
T J Randall
Junior Member
I'm looking at aluminum, and it's a pretty heavy gauge so I think I'll be able to get away with it. I've got some pretty good sills, but am a bit worried about stress cracks if I go this way.
Old 06-02-2006, 07:25 PM   #4
texascowboy593
texascowboy593's Avatar
Welcome form College Station! Great little steakhouse y'all got up there! I've seen it done before. There is a car/truck show here next weekend. I was at it 2 years ago and there was a 67-72 that had a diamondplate bed and inside walls...If it is back this year, I will take pics and post them for you...Good luck!
"The rays of light thru the Shiner Bock bottle make me wanna turn the key and put down the throttle...and get lost down 35" - Jason Boland
www.YouTube.com/user/593Films - Watch My Videos!
1977 Silverado K10
2014 Dodge Durango (Wife-mobile)
2008 Dodge Ram Lone Star Edition (Daily driver)
texascowboy593 is offline   Reply With Quote
Old 06-02-2006, 08:06 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Have you priced the materials you're looking at? 6 foot by 6 1/2 foot is what you'll need...won't be cheap.
Old 06-02-2006, 08:15 PM   #6
TugOwar
Howdy from South Texas! Good luck with that bed floor.
TugOwar is offline   Reply With Quote
Old 06-02-2006, 08:21 PM   #7
boraxman
Keepin an eye out
boraxman's Avatar
Sounds like a good idea
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 06-02-2006, 09:14 PM   #8
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
I was wondering how much more wood could be,Diamond plate isn't cheap.
Of course if you have it use I say
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 06-03-2006, 12:04 AM   #9
Longhorn Man
I considered this a long time ago for a short fleet I had, the floor was sagging between the cross rails, like 3 tons of driveway rock was loaded in it, (knowing the PO, it wouldn't suprise me one bit either) I honestly can't remember the numbers, this woulda been back in like 2000 or so, but I remember pricing a wood floor being just a tick more.
Old 06-03-2006, 06:00 AM   #10
You`re not the first to "ponder" this.Take a trip to Solution,TX.You`ll find your answer.Sorry,my middle name is Ass.
Steel is cheaper and stronger for this use."Converting" to wood is where it gets expensive,not the wood itself.I mean,you can come up with your own wood for cheap.But,bedstrips,bolts,modify/change front panel,and don`t you need different supports?The diamond plate will prolly need to be ordered in over 4' wide if you don`t want a seam.
Old 06-03-2006, 09:25 AM   #11
phase_one
Steel is much cheaper and stronger. I used steel for my bed. I used two sheets, I think it was $110 for both. Price was the driving force on this decesion. Alum. was over $100 per sheet. This was in 03. Welcome to the board
11 Surbaban
70 C 10
still in progress
phase_one is offline   Reply With Quote
Old 06-03-2006, 10:42 AM   #12
clay68c10
clay68c10's Avatar
I think it would look great. But I wonder about electrolysis/corrosion from the combo of alum & steel. Maybe using thin rubber strips under the alum to mount it would help?? Or you could use spray liner on the inner bed sides, gate and front panel, then liner the tops of the cross sills. Just something to think about...
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 06-03-2006, 04:08 PM   #13
Longhorn Man
I don't think that would be too much of an issue. You need some kind of fluid to act as an electrolite to really have issues, this is why boaters hate mismatch metals. However, the alluminum grill and trim bolts up to the steel truck, and stainless steel screws are driven into the metal with no real issues.
Old 06-03-2006, 05:08 PM   #14
T J Randall
Junior Member
Thanks for all the inputs everyone, I'll keep you posted on the progress. Special-K hit it right on the head with his response about additional pieces/parts, that's why I'm leanin' toward aluminum or maybe even steel like phase one suggested. The Ponder steak house is still cookin' too.
Old 06-03-2006, 05:16 PM   #15
dennislbrooks
dennislbrooks's Avatar
You can go with 14 ga deckplate - steel -- once fitted, have it sandblasted both sides if you can before rolling -- Zero rust on it or equivalent. You could scotchbrite the whole thing with a drill before cover application to both sides. You will have 2 symmetrical halves that can be welded longways in the middle. I got my plate from American Steel in Dallas--next to Pilgrims Pride. I have a plywood template with all hole locations that can be borrowed. Zero rust is a urethane base that can be overcoated with any automotive finish. I have many pics. Flower Mound
dennislbrooks is offline   Reply With Quote
