How to replace a steering coupler
How do I replace a steering coupler on a 1978 chevy van, 305 automatic? I need help. Thanx, Michelle
Re: How to replace a steering coupler
Michelle, welcome to our addiction. Sorry I dont have the answer for you. However if you dont get a good answer here, delete this thread and repost in the truck or perhaps the burb/blazer forum. Granted they are not exactly the same veh but somethings are VERY similar. If you need other help with this site or anything in particular feel free to ask any of the mods or volunteers... that is why we are here..
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
Okay thank you and thanx for the welcome. Michelle
are you talking about the "rag" joint coupler // if so and you need to replace the flexible middle it's just a matter of 2bolts and nuts plus 2 stationary pins unbolt the nuts and bolts and slip the old rag joint out and put the new one in // if you want to remove the whole thing theres a collar that has a bolt going sideways thru it that fits thru a machined dimple that holds it in place
welcome from daytona beach where are you in florida
I live in Jacksonville. Can I send you a picture to show you the rag joint? I had someone else say I had to take out the whole steering wheel etc. I sure don't want to do that. Michelle
i just did a quick look in a manual// it looks like the easiest way is to to unbolt the steering box from the frame you don't have to disconnect steering hoses or pitman arms or tierod ends just unbolting the box and let it hang or possibally you can leave one mounting bolt in loose and let the box pivot foward to get the clearance you need to replace that joint// i believe if you just need to replace the flexible rubber piece if you just loosen the steering box mounts there'll be enough slack to get it in
I'll try. This is my sons and my project. He's 16 and still learning. I'm still learning too. I'm still learning what steering parts are called. I do know what tierods and balljoints are. Our manual shows nothing. Thank u for help.
doesn't the shaft collapse on vans? i just unbolt the rag joint from the box and collapse the shaft. never unbolted the steering box
The shaft doesn't collapse. Just remove the 12 point bolt on the steering coupler shaft. This bolt is the one on the coupler that holds the shft onto the steering box. Then unbolt the 2 bolts holding the coupler to the steering column.
Then go under the dash & loosen the 2 bolts holding the column to the dash. Should now be able to pull the column up a few inches & then have the room to get the coupler off the steering box. Here's a pic for you. Message me if you need any other help. Brad
55 Chevy small window.Have had 45 years. 66 FJ40 LandCruiser.Rock crawler/camping. 72 Chevy 10 Van,short wb,454. 78 Chevy 10 Van,short wb,350 77 Chevy Suburban. Silverado 20 Trailering Special.454,turbo400.Currently blown apart. |
I learn something new everyday
The coupler turned out to be okay. Thanx for all help.
