Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 09-24-2006, 01:14 AM   #1
shifty
Questionable
shifty's Avatar
press brake + drill press purchase advice
Hi all,
I am looking for an inexpensive drill press and press brake for my shop. I do not need anything fancy and don't need to bend or drill anything larger than, say, 10 gauge mild steel.
I saw they had a 12 ton press brake at Harbor Freight for around $100. I also have seen several drill presses, but I'll admit, it's daunting to find the right one, or to even know what the heck I need in a drill press...I found a 16.5" floor standing one, old Craftsman for $100 on craigslist....not sure if I should pick it up?
I'm sure some of you guys can give inexpensive recommendations, so I'm curious to see if anyone has good advice.
Mind you, I am not going to be running a freaking shop and these tools will not get more than a dozen uses per year, so I am not looking for anything fancy (hence why I would buy something from HF)
Thanks!
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 09-24-2006, 01:40 AM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: press brake + drill press purchase advice
I picked up a $150 Home Depot drill press three years ago (it's a Ryobi)... I had to have one that day for something and figured that when it broke I would replace it with a "nice" one... it's still going strong and gets used quite regularly.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 09-24-2006, 05:50 AM   #3
cdowns
cdowns's Avatar
i've got an older craftsman drill press it was about top of the line back then// i like big heavy bases, big heavy girder , powerfull motor, big work table that you can easily clamp things to that tilts both left and right, the belt should be easy to change ,tighten and adjust speeds with, i also needed a unit that you can easily ghange out the chuck and would accept a 1 inch chuck// the thing to watch on used machines is worn bearings and stripped gears in the spindle and feed area HEAVY is good
Old 09-24-2006, 06:39 AM   #4
Search the local paper:classifieds and sales/auctions.The old stuff is all industrial rated.I got a 5' brake for $75 at a sale.
Old 09-24-2006, 10:45 AM   #5
Fred T
Cantankerous Geezer
Fred T's Avatar
For a drill press, get a floor mount. I bought the HF 43389 a few years ago. Only problem has been the switch, poor design that I had to replace. Unless you have to have one right away, wait for HF to have a sale. The older used presses are good, but around here people want too much for them.
I don't know about the HF brake. You can do some comparing at Northern Tool
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 09-24-2006, 10:59 AM   #6
Shane
Shane's Avatar
looked at this same model yesterday at our local HF ... not industrial grade, but not bad for home use.
http://www.harborfreight.com/cpi/cta...emnumber=91012
Shane is offline   Reply With Quote
