Old 08-21-2006, 01:21 AM   #1
muddpile
muddpile's Avatar
Changing Timing Chain?
What do I need to know to change the timing chain and gears on my 350? I have the cover off already, and the chain is quite loose. I picked up a double roller/sprocket set, but I want to make sure I know what I'm doing so I don't screw it up. Are there any special tools required? What about precautions? Any help at all would be great. Thanks!
muddpile is offline   Reply With Quote
Old 08-21-2006, 01:27 AM   #2
c-1072
Re: Changing Timing Chain?
get a manual to be sure so its right in front of you, this way you can double ck everything . It is realy simple you already did the hard part . you just need to line up the two dots on the gears so they are in line top (crank gear ) to bottom (cam gear ) and swap the gears and chain out .
c-1072 is offline   Reply With Quote
Old 08-21-2006, 01:33 AM   #3
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
remember that quality sets will have multiple key ways in the lower gear for 0*, -4*, +4* of timing. you will only want 0/+4* unless your running massive nos/blower. make damn sure you get the marks right on, it can be a severe pain to get them moved just one tooth but you need to be dead on the marks.
trkklr77 is offline   Reply With Quote
Old 08-21-2006, 02:57 AM   #4
muddpile
muddpile's Avatar
I think the small gear only has one keyway slot cut in it. What is the best method for getting the old gears off? I haven't tried anything yet. The top one looks like it just unbolts with three bolts, where the bottom looks a bit different. Do I need a gear puller or something?
Old 08-21-2006, 03:03 AM   #5
trkklr77
trkklr77's Avatar
yes you need a puller.
as for putting the new one on, o have always tapped it on with a peice of 1.25" pipe witha cap on it and GENTLE!!!!!!! taps, otherwise get an installer.
Old 08-21-2006, 07:24 AM   #6
rage'nrat638
rage'nrat638's Avatar
heres the bottom balancer installer
rage'nrat638 is offline   Reply With Quote
