Old 07-24-2006, 04:50 PM   #1
cell
Active Member
cell's Avatar
should timing be set "by the book", or tweaked?
My Haynes manual indicates my idle advance should be 4 degrees BTDC. Is that it? End of story? Or is this something which should be fine tuned?
I have heard horror stories of people shortening the life of their motors by "tweaking" their timing, and my 292 doesn't have any provision for knock sensing, so I don't see how I would even know if I had pushed things too far until my pistons start grenading...
cell is offline   Reply With Quote
Old 07-24-2006, 05:24 PM   #2
jbon64
jbon64's Avatar
Re: should timing be set "by the book", or tweaked?
"seat of the pants " has always been good to me. what seemed to work best for me was advance the timing till it just starts to ping , then back it off a degree or 2 . hope it works for you
hey.....smell my finger
64 nova wagon , 63 nova convertible
jbon64 is offline   Reply With Quote
Old 07-24-2006, 07:52 PM   #3
ThatOneBlue67
I survived Dead Man's Curve.
ThatOneBlue67's Avatar
I keep mine at 4 deg. BTDC. Since tuning it to that (as apparently I was driving it with the wrong ignition timing for a short time) the motor stopped running so hot and held idle a LOT better. They're not performance or anything, you just gotta eye it at 4 deg BTDC.
"The people should not be afraid of their government. The government should be afraid of it's people."
"The Hurricane"
1967 Chevrolet C10
350 Eight Cylinder, 700R4 BowtieOverdrive
Cherry Bomb... Disturbing the Peace Since 1968.
ThatOneBlue67 is offline   Reply With Quote
Old 08-22-2006, 06:04 PM   #4
cell
Active Member
cell's Avatar
agreed ThatOneBlue67. I just set to 4 degrees advanced (as per recommendation in the Haynes manual), and it runs like a champ. engine warms up and then holds steady at the same temp.
Old 08-22-2006, 07:18 PM   #5
76bonanza
76bonanza's Avatar
Just depends on the motor but I always am of the rule the most intial advance it can take with out pinging will net the most power. I have Never had any heat issues or idle problems. Mine is a little more than stock maybe 330HP and it is set at 13 deg with nor problems.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 08-22-2006, 07:28 PM   #6
Blazer1970
Blazer1970's Avatar
I agree, but I would not suggest this method unless you are sure that you know what spark knock sounds like. You can destroy an engine with uncontrolled or undetected detonation (pre-ignition, spark knock, knock, pinging, and detonation are all terms for the same thing). It will start by breaking the upper ring lands off of the pistons, then it will break compression rings leading to scored cylinder walls and sometimes it will put holes in pistons. Detonation will usually occur first when the engine is under load (almost lugging).
Blazer1970 is offline   Reply With Quote
Old 08-23-2006, 06:48 AM   #7
I use the up to ping/then back a bit method for great results.If you don`t hear a ping,it ai`nt pingin`.
Old 08-23-2006, 07:05 AM   #8
cdowns
cdowns's Avatar
if you haven't degreed your cam so that you know exactly where the timing marker is in relation to TDC then it's just guesswork anyway is it not??
Old 08-23-2006, 09:35 AM   #9
Premium72
Premium72's Avatar
i had to play with mine a bit after intsalling the cam, was to advanced and i broke 2 starters before i figured it out. but you sound like your on the rite track .
Premium72 is offline   Reply With Quote
Old 08-23-2006, 09:43 AM   #10
jacobs
jacobs's Avatar
It depends on how the enging is built, fuel used, AND altitude. Where I live at 9,000 ft, with a factory engine, I must run 4 to 6 degrees aditional initial advance or it runs like a dog. Your ear is the best way to set the timing unless you're using an open exhaust and can't hear the enging ping.
jacobs is offline   Reply With Quote
