did 292 c10's get 4:11's? std
Seems like I read somewhere that 292 half tons got 4:11's std. Is that so? My old orig 67 has the glove box door sheet torn off. Is there anything else the 292 motor truck got that the 250 didn't standard?
![]() Join Date: Nov 2005
Re: did 292 c10's get 4:11's? std
My 70 c10 w/292 came with 4.10's , can't say for others .
Can-Am Motorsports 37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser . 64 Biscayne 409 2x4 4 speed 4.11 posi 65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon) 68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD) |
![]() Join Date: Feb 2002
My '68 C/10 stepside came w/292, SM465 and 3.73:1 12-bolt open differential. Also 7.00 x 17.5" tires specified on the glove box door.
You won`t find gear ratios on the VIN-spec sheet.I believe the I6/manual combos came through w/4.11s unless another ratio was specified,up or down.Everything else would be the same on a truck whether it had a 250 or 292.Only pieces that were required for that particular engine would be different,like motor mounts,etc.
My 250 with 3spd manual came stock with 4.56 gears, its not an option listed on the build sheet (of which there were only 4, so I figured that was just what all I6's came with)
1969 SS 350 Camaro Sold 2008 1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's ![]() 1980 Chevy Malibu 2 dr Sold 2007 1993 Olds. Cutlass Ciera Wagon Traded 2006 2003 Saturn L200 w/5pd. D/D My list spans 5 decades with One common thread.....GM! |
its all about the +6 inches
Shelby, yours is a 3/4 ton, so the standard gears is a 4.56.
My books show 3.73 being standard with both inline engines. *standard includes 3 speed transmision, when you get other trannys, other gears become standard with that engine/tranny combo* Last edited by Longhorn Man; 08-24-2006 at 03:14 PM. |
My 68 C10 Burban came 4spd 292 w/ 3.73
