Old 09-28-2006, 01:50 PM   #1
arkracing
Weekend Warrior
Stupid Question - '67 -'71 K10 vs. K20 Frame (Different??)
so is there any differance between a K10 and a K20 frame?
I know that the springs and axles are differant - but what about the actual frame - is it beffier @ all? - seems to me that they would be close to being the same???
or no?
anybody tow a car trailer with a K10??? - how does the 1/2 ton handle it?
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 09-28-2006, 07:41 PM   #2
qksilver
Re: Stupid Question - '67 -'71 K10 vs. K20 Frame (Different??)
If I remember correctly Longhorn said that the 1/2 and 3/4 are the same, it's the 1 ton frames that are beefier. Towing with a 1/2 depends on the load and how you are towing it. Weight is really the major factor because that effects everything. How it pulls, steers and most important, stops.
qksilver is offline   Reply With Quote
Old 09-28-2006, 07:46 PM   #3
arkracing
Weekend Warrior
Cool - Anybody else know about this????
2cd opinions???
Here is a thread on my recent endevor - I have a few questions in this thread too - about Transfercase ID, Front Hub ID, and Tire sizes??
Thanks,
Andy
-'66 C10 Suburban
Old 09-29-2006, 12:35 PM   #4
Yukon Jack
Yukon Jack's Avatar
The Chevy restoration packet shows there is a difference in the 10, 20 and 30 frames. The section modulus varies between each. I find the following definition: The section modulus largely determines the flexural strength of a beam of given material.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 09-29-2006, 02:13 PM   #5
arkracing
Weekend Warrior
That is kinda hard to decifer - but i'm guessing it either means that the section that goes under the cab area is "taller" or has a differant alloy of steel.
Seems odd that GM would make 2 different frames for the 10 & 20.
I'd be curious to see some dimensions on someone's original 20 series truck vs. a 10 series frame to compare.
(anybody already done this?)
-'66 C10 Suburban
Old 09-29-2006, 09:45 PM   #6
They`re the same.
Old 10-01-2006, 09:15 AM   #7
arkracing
Weekend Warrior
They`re the same.
so if I put 3/4 ton springs and axles in my K-10 I have a K-20 (I know it won't be the real deal - but it is the the same as a factory K-20?)
This is dangerous - I already have all kinds of ideas for my new ride.
-'66 C10 Suburban
Old 10-01-2006, 11:26 AM   #8
Yeah,the springs and axles/brakes.Both have Dana44 front axles with the difference being in the hub/brake area.
