Old 09-20-2007, 06:32 PM   #1
Sadist
New Board Member, New Jimmy
Hey all,
I've been lurking here for a while, I've finally pulled the trigger and got on the board...
Just picked up my first Jimmy. It is an all original rig, a 72 with under 60K on the clock. The first owner ran this thing for 10 years, then parked it after his trans let go, it's been quietly rotting away ever since...
It needs a lot.. rocker boxes are shot, rear quarters as well as both door bottoms are trash, the front is okay, just a little screwed up... it has a good frame, roof and windshield frame, i'll need to reseal everything and go through the driveline.
The plan.. return this to stock form.
I have ordered the bulk of the sheet metal needed to whip the rockers back into shape, and will tackle that repair while the body sits on the chassis. Then i'll start on the quarters, and do the door bottoms.
I figure doing it this way will save space in the shop, I'll only have the body off the frame for a short while, (i'll be sure to add bracing to the door frames).
Any thougths? Am i right to try to build the bulk of this thing while on the frame?
I should have the sheetmetal i ordered by the end of next week, I'll try to get pictures of my progress and upload them. I hope to get the front clip off by saturday as well as the engine / trans and t'fer case out.
Sadist is offline   Reply With Quote
Old 09-20-2007, 06:50 PM   #2
jaros44sr
jaros44sr's Avatar
Re: New Board Member, New Jimmy
Post up some pics. when you get a minute. J.
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 09-20-2007, 07:06 PM   #3
Thealien
Thealien's Avatar
welcome from about 30 minutes south of you
Old 09-20-2007, 07:19 PM   #4
Long Roof
Old School, New Style
Long Roof's Avatar
Welcome, welcome, welcome fellow 72 Jimmy owner!
NOW POST SOME PICS! (please)
The Good:
- 72 GMC Jimmy 4x4 - 307 cid / 350 th
- 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th
- 96 Chevy Impala SS - mainly stock
- 98 Chevy Tahoe LT 4x4 - all stock
The Bad:
- 86 Chevy Suburban 1/2T 4x4 - winter beater
The Ugly:
- 72 Chevy Suburban 1/2T 2wd - parts truck
Long Roof is offline   Reply With Quote
Old 09-20-2007, 08:30 PM   #5
jaros44sr
jaros44sr's Avatar
The masses are getting restless already, I hope you have a camera or it could get ugly
SAFETY FIRST
AS usual, off topic
Jim
Old 09-20-2007, 08:38 PM   #6
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
From West TN
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 09-20-2007, 08:47 PM   #7
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
Unfortunately this is true!
Welcome from Michigan!
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 09-20-2007, 10:39 PM   #8
Sadist
Got it... Pics...I'll try to get some up tomorow once i get it on the lift...
I managed to get the front clip off tonight, the bulk of the bolts even came out!! I snapped one, and used the torch on the radiator support body mounts...
before sunday, i hope to get the seats out and HOPEFULLY do some sandblasting to the spots where the new metal is gonna go.
Thanks for the welcomes!!
John
Old 09-20-2007, 11:02 PM   #9
crzngmychvy
"1972 C5"
crzngmychvy's Avatar
Welcome from socal!
- 72 2wd Blazer ...sold...
2wd Blazer Page
crzngmychvy is offline   Reply With Quote
Old 09-21-2007, 09:16 AM   #10
1971K54X4
Member
to the board from Iowa.
Korey
1955 Bel Air 2 door hardtop
1971 Blazer 4x4
1973 Z-28 Prostreet
1971K54X4 is offline   Reply With Quote
Old 09-21-2007, 09:18 AM   #11
Yukon Jack
Yukon Jack's Avatar
Welcome to the board. I think you are wise to do as much repair work with the K5 on the frame. If you take it off the frame to do repairs you will want to do lots of reenforcing to keep the body positioned correctly. These bodies will sag and get out of shape pretty easy.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 09-21-2007, 10:46 AM   #12
Sadist
With the aid of the forktruck and a helper, I got the front clip off this morning before work... looks like i'm in for a radiator support as well as inner fenders... bummer... Working on pics..
Old 09-21-2007, 10:59 AM   #13
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Welcome from Seattle. Although what your doing is way, way beyond my skill set, everything I've read on the board says your doing it the right way. Get the body panels replaced while it is on the frame. It is best with the top still in place too. These trucks tend to flex a lot which changes the spacing on the body panels. You may check to see how shot your body mounts are before you align any critical areas.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 09-21-2007, 01:13 PM   #14
Sadist
just a couple of quick ones...
Old 09-21-2007, 02:33 PM   #15
72BlckButy
Tot Roddin'
72BlckButy's Avatar
to the board from Mid-MO!!!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-21-2007, 08:55 PM   #16
Long Roof
Long Roof's Avatar
Looks like this one will keep you busy for awhile. Good luck and keep us posted.
The Good:
The Bad:
The Ugly:
Old 09-21-2007, 09:35 PM   #17
Sadist
yeah, she's a mess... I've had her 3 days now...
engine is out, i hope to have the rest of the driveline out tomorrow.
Old 09-21-2007, 11:13 PM   #18
krue
Designated A-hole!
krue's Avatar
Welcome to the board from South Mississippi! Make sure to start a project thread on the 67-72 board.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 09-21-2007, 11:32 PM   #19
jaros44sr
jaros44sr's Avatar
Really cool thread.You've got me hooked already. Forklifts, every man should have one...I've been using one for 35 years, amazing what you can do with one.
Good luck, it seems like you have it well under control. Nice to see another one brought back. J
Keep the pics. coming, very entertaining
SAFETY FIRST
AS usual, off topic
Jim
Old 09-22-2007, 12:04 AM   #20
CJ5 Convert
CJ5 Convert's Avatar
Welcome from sunny New Mexico.
- Jason
Orange Crush - 1969 K5 Blazer CST 4WD MONEY PIT
1975 CJ5 Renegade - Levi's Edition - 304 V8 original paint
CJ5 Convert is offline   Reply With Quote
Old 09-22-2007, 03:05 AM   #21
72armyswbtruck
72armyswbtruck's Avatar
from Idaho,
Man that thing needs alot of work, good luck and I am glad that you are restoring that one and not letting it get parted out and then crushed, You have come to the right place for restoration tips and parts. Good luck and keep those pics coming
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 09-22-2007, 04:23 AM   #22
Eddie47
Eddie47's Avatar
to the board from Florida
Eddie47 is offline   Reply With Quote
