Old 11-10-2006, 10:11 PM   #1
bad_turbo
turbo enthusiast
bad_turbo's Avatar
72 motorhome info
I'm looking into buying this new project, but can't find alot of info on these old motorhomes on this site. Can anyone recommend another place to find more info on them. Thanks
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
Old 11-10-2006, 10:13 PM   #2
bad_turbo
turbo enthusiast
bad_turbo's Avatar
Re: 72 motorhome info
few more:
Old 11-10-2006, 10:14 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
pretty neet how they converter that one ton to a 4X4... never seen that on a motor home.
Old 11-10-2006, 10:15 PM   #4
bad_turbo
turbo enthusiast
bad_turbo's Avatar
glovebox door had sticker removed before painting
Old 11-10-2006, 10:15 PM   #5
1969k10stepside
Cant help you about your question but that would be a cool project,and if I seen correctly it had a tilt collumn.
1969k10stepside is offline   Reply With Quote
Old 11-10-2006, 10:22 PM   #6
bad_turbo
turbo enthusiast
bad_turbo's Avatar
Yah, it has tilt, a/c that works, p/s, pb (drums), interior is almost perfect, paint is bad, big block runs like new, but the truck is not quite a 4x4. It just has that dana 44 sitting there, no driveshaft or t/c. Has the hole in the floor for the shifter and it has the shifter laying on the floor. Truck is from Idaho, now located in socal.
Old 11-10-2006, 10:25 PM   #7
1969k10stepside
I dont think that is a small block, is it?I cant tell..
Old 11-10-2006, 10:27 PM   #8
stllookn
Saving 1 truck at a time!
stllookn's Avatar
I have literature on the Open Road line but not that one. The 4x4 is too cool...I wanted to do that conversion on Livrat's motorhome but I was too late...LOL!
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 11-10-2006, 11:04 PM   #9
CPNEJR
CPNEJR's Avatar
1969k10stepside your correct it isn't a small block. it looks to be either a 396 or a 402
(Only) Member of the CPNE Fan Club Aint that the truth
67 C-10 350 with 3-speed tranny and 308 gears swb step
82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine)
72 Chevy K20 Suburban (future project)
70 Chevy K20 now 68 GMC K2500
2003 Chevy 2500hd ccsb 4X4 (daily driver)
CPNEJR is offline   Reply With Quote
Old 11-10-2006, 11:06 PM   #10
1969k10stepside
Yeah,its a big block,look at the heads and the dipstick looks to be on the other side than the small block
Old 11-10-2006, 11:19 PM   #11
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
I am confused. I see what looks like an automatic shifter. Then it looks like a 4 speed manual shifter and clutch pedals. What the heck kind of Frankenstein is this thing? What kind of transmission does it really have? It will make for a sweet rig once it is all put together correctly.
DirtyLarry is offline   Reply With Quote
Old 11-11-2006, 01:17 AM   #12
Bob Moore
A 72 truck should have disc brakes. That probably did until they changed to the D44. I also thought there were NO big block 4X4's from the factory. Somebody has made those modifications - either at home or the conversion company. I would bet on home brew.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 11-11-2006, 01:24 AM   #13
Musclerodz
there is one of those just a couple miles from my shop in the city.
Mike
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 11-11-2006, 05:24 AM   #14
Bob B.
The VIN starts 'CCE', so it's safe to say it was originally a 4X2. McNamee Coach was an old RV manufacturer that built a lot of campers back in the
60's, I imagine they are long gone now. Open Road built a lot of frame-mount camper bodies on '67-'72 C-30 chassis, seems to be a few of those still around. My favorite was the Travel Queen, which used a C-20 (Chevy or GMC) cowl chassis, like a school bus.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 11-11-2006, 05:50 AM   #15
Longhorn Man
they also never made a one ton 4X4.
Old 11-11-2006, 08:17 AM   #16
72freak
Rottenwood Garage Member
72freak's Avatar
there are a few guys on the board who have these or had these..give it time.....someone will pop up with some info!!!
Very cool find!!!!!
72freak is offline   Reply With Quote
Old 11-11-2006, 11:49 PM   #17
Rod
Interesting project. From what I see it started out as a 2wd long wheel based dually...with an additional motorhome body added then a front 8 bolt non-dually front diff. BB looks original to the 2wd era to me. Check how those front springs are attached.
Bolted or riveted spring hangers? More than likely bolted which would be a home made or aftermarket addition.
It's something I'd look at for a project form myself though too.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 11-12-2006, 12:04 AM   #18
bad_turbo
turbo enthusiast
bad_turbo's Avatar
Unhappy Re: 72 motorhome info
Bad news about this motorhome. It was sitting on a hillside when I took these pics and apparently the owner didn't have the brake set, so in the middle of the night the truck took off down the hill about 100 yards, hit a boulder about the same size as the motorhome and flipped it on its side. I called the owner to tell him I would buy it from him and then he told me this news. Good news is the price went from $1800 to $600. Bad news is I don't have the skills to fix the motorhome body. What should I do?
Old 11-12-2006, 12:27 AM   #19
DirtyLarry
DirtyLarry's Avatar
Man that is a drag. Shoot, offer him $500 for it anyway and finish the 4x4 conversion then add a flat bed. That would still be cool. What transmission does that thing have anyway?
Go back and get us more pictures of the aftermath.
Old 11-12-2006, 01:45 AM   #20
bad_turbo
turbo enthusiast
bad_turbo's Avatar
I really wanted the motorhome. I already have a 1 ton dually flatbed. The trans was a 4 speed. He is going to send me some pics of the damage. I will post them here.
Old 11-12-2006, 02:14 AM   #21
classicchev
classicchev's Avatar
Its never too late!!!
67- 72 Parts collecter
classicchev is offline   Reply With Quote
Old 11-12-2006, 02:20 AM   #22
classicchev
Its never too far gone. I ripped apart, and rebuilt mine in a weekend. Now I just have to get at it again. You could always bring it up to me and I will fix it for you. Here are a couple shots of mine in progress
Old 11-12-2006, 03:30 AM   #23
stllookn
stllookn's Avatar
Bob, I can only find the Imperial, Royale, Monterey, Bel Air, Newport, and Belmont in my Open Road catalog. Most of the trucks shown are duallies and 1968 vintage. They may have changed the model names in later years. They called them "House Cars" back in the day...LOL!
classicchev...don't tempt me! I still have one more Longhorn to pick up and I am asking myself WHY?
Old 11-12-2006, 10:09 AM   #24
extd56
extd56's Avatar
Here is another ad on Craigslist for a 1967 Chevy motorhome for sale.
http://sfbay.craigslist.org/eby/car/233306734.html
extd56 is offline   Reply With Quote
Old 11-12-2006, 11:55 AM   #25
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I know Da'burb had or has one also but I don't know what model.He is the kind of guy who does a lot of research on stuff and has a ton of knowledge about these trucks.Maybe he will see this post and reply.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
