Old 11-13-2006, 09:07 PM   #1
leftcoast66
leftcoast66's Avatar
Headers on lowered truck
Mk, so right now I've got the Hooker Super Comp headers and they sit way too low for a lowered truck. I'm hoping to make the frame lay on the ground and curious what other people with lowered trucks are running for headers to clear the frame yet remain long tube if possible because I like being able to dragrace it w/ straight pipes
leftcoast66 is offline   Reply With Quote
Old 11-13-2006, 09:28 PM   #2
62 short step
62 short step's Avatar
Re: Headers on lowered truck
Block hugger headers would work. Look up Patriot Headers.com.
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 11-13-2006, 11:33 PM   #3
Chevy Fleetside
Chevy Fleetside's Avatar
he wants to stay long.. You might have to get a kit and weld your own together if you want to stay level with the frame.. I have heard that 3/4 chevelle headers work also, but they point down.. You might want to do some searching on the internet and talk to some header makers.. They might be able to help you better..
Chevy Fleetside is offline   Reply With Quote
Old 11-14-2006, 07:19 AM   #4
gostranger
65 suburban vortec 5.3 bagged
gostranger's Avatar
i think making your own or block huggers are your only choises i looked and tried a bunch of different headders and they didnt make enough clearance good luck
gostranger is offline   Reply With Quote
Old 11-14-2006, 01:28 PM   #5
65-65
How's about running block huggers with dumptubes?
65-65 is offline   Reply With Quote
Old 11-14-2006, 04:57 PM   #6
leftcoast66
i'd like to stay with the long tubes rather than a dumptube. I'm debating talking to some people and seeing if I can cut mine apart a bit and make them stay above the frame and keep the super comps.
Old 11-14-2006, 05:26 PM   #7
71chevylowrider
71chevylowrider's Avatar
I have the Hooker Super Comps & they clear, my crossmember/lower a-arms are lower then they are.
71chevylowrider is offline   Reply With Quote
Old 11-14-2006, 06:19 PM   #8
leftcoast66
Wierd, mine are about 21/2 to 3 inches below the frame. Are yours full long tube or shorty headers, cuz that may be the difference, and I know the 67-72 guys are having trouble finding long tubes as well, I'd let them know also that yours work
Old 11-14-2006, 07:12 PM   #9
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Not sure if they would fit your application, but mine are mid length, and
were 4.5 inches higher than the long tubes that I removed, hope that it
helps, pm me if you need part #'s, mine are for a 67-72 4wd application.
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 11-14-2006, 08:15 PM   #10
71chevylowrider
They came on the truck when I bought them, the last time I was looking around under there I thought they went into the collectors back behind the motor which made me think thery were full lenth, shortys hit the collectors along side the motor don't they?
Old 11-14-2006, 08:31 PM   #11
leftcoast66
Sounds like you might have the mid length headers. I may end up getting them, but I'm debating seeing if I can find a way 2 cut and bend mine up so that they will sit up in the frame cuz I hate getting rid of these. It just sounds so dang amazing with them on the 350
Old 11-23-2006, 10:41 AM   #12
Pritchard1970
To Left Coast,
I am working on a 62 fleetside and am looking to lay frame as well, it has been quite the process with the air bags power steering conversion and whole front crossmember conversion...I looked into headers for the 350 I am running in it(it will soon be installed) and I will be running hedman 68600, I have great luck with them in the past on my chevelles and my 68 camaro...hope this helps...by the way they are intermediate length but they flow great....how are lowering your truck? I am looking for some tips on how to do this thing right the first time...thanks and good luck
Pritchard1970 is offline   Reply With Quote
Old 11-23-2006, 11:33 AM   #13
kdevore2
Check this guy out on eBay. He might have what your looking for. I've not used his headers but was considering it. These are stainless but he has others that are ceramic coated.
http://cgi.ebay.com/ebaymotors/CHEVY...mZ260053232697
kdevore2 is offline   Reply With Quote
Old 11-24-2006, 09:24 PM   #14
63sbssbbw
UCA63
63sbssbbw's Avatar
Basic Air suspension in this months HOT ROD mag
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 11-24-2006, 09:51 PM   #15
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
I'm going to be running a mid-length Edelbrock on my truck. I have test fit them with the engine still on the frame and they dump out at the top of the frame rail about even with the back of the block. Photos of how they fit are on the thread below:
http://67-72chevytrucks.com/vboard/s...=215994&page=2
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 11-30-2006, 01:38 AM   #16
Rollie396
someday it will be done!
Rollie396's Avatar
I say modify your existing headers if you're otherwise happy with them.
Get yourself a few 180 deg. mandrel bends and go to town!
check out this website too,I learned a lot from it. www.headersbyed.com
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore.
'80 LWB 2wd beater
'67 GMC long fleet (cab donor)
'66 long step (parked till it's turn comes around)
'65 short step (parts truck that will donate it's bed and possibly frame to the '66)
'06 Grand Prix wife's car (she hardly lets me touch it)
my pics
Rollie396 is offline   Reply With Quote
Old 11-30-2006, 02:00 AM   #17
leftcoast66
I know I'm gona build a setup similar to the dropmember for my c10, so I'm thiknin I'm gonna while I'm there build it so I can make the motor sit way higher, high enough 2 tuck the headers (2 1/2 inches) and then raise the firewall as well since the distributor barely clears anyways. It's gonna be a long summer w/ all this work but I'm excited.
Old 11-30-2006, 03:54 AM   #18
Rollie396
Rollie396's Avatar
wow that is an ambitious project!I wonder if you'd have to tunnel the cab floor too?How about driveline angles?
If you do go that route,make sure to post lots of pics for us!
'80 LWB 2wd beater
my pics
Old 11-30-2006, 01:08 PM   #19
leftcoast66
Ya, I'm thinking I may have to mess with the floor a little bit, but that hsouldn't be bad. It is pretty high as it is and it's the two piece driveshaft which helps with raising the transmission as well as lowering the truck so much. It's quite ambitious, but I'm planning on pulling the motor to do body work anyways, so it's just the little extra's such as raising the firewall which will be different.
Old 11-30-2006, 02:29 PM   #20
SIR
SIR
SIR's Avatar
....IMHO...why would you want to "lay-frame" in the first place? if something goes wrong with your system..YOUR SCREWED! granted it looks very cool but unless it's a "trailer-queen" I would keep "driveabaility" in mind as for your headers... if you have the time to completely re-fabricate your floors and firewall I would save the time and money and have a pro custom build your headers that way you can be driveing your truck in less than a week rather than however long it would take to fab up a new floor and firewall..just a thought...
66long low fleet http://community.webshots.com/user/LVNR66
SIR is offline   Reply With Quote
Old 11-30-2006, 06:31 PM   #21
leftcoast66
I like it low and like the look and the challenge of building it to lay frame, that's howcome I'm doing it. I also don't want it to be a trailer queen because I enjoy driving and believe that if I'm gonna dump a bunch of time into a project, I wnat to enjoy it and that's my way of enjoying it. Driveability is fine if you do good work and don't half ass stuff. I've never had a bag pop and this was my daily driver on bags for 2 years after I got my license. I'm also willing to refab the firewall and the driveshaft tunnel because I have the knowledge and time, but since I'm 19 and going thru college, I don't exactly have the money, nor the want for someone else to do something for me. I'd rather learn, possibly it'll be the hard way, but I'd rather learn to do it myself so then possibly I'll be able to open a shop after college rather than pay someone else to do something which I'd like to learn to do.
Nice lookin frame, really great powdercoating setup and headers.
Old 11-30-2006, 11:24 PM   #22
SIR
SIR
SIR's Avatar
...very cool great ambition!! I like that "can-do" attitude....keep us posted on your progress,
and what you see under my truck is many hours of clean up wire brushing and sand blasting ...and it's all paint, I don't have that kind of money ether..
Old 12-01-2006, 12:28 AM   #23
leftcoast66
Kool deal. Ya, I'm hoping over christmas break to get the back end all notched and setup, so i'll start posting then. That's great to see someone out gettin dirty as well
Old 12-01-2006, 12:44 AM   #24
SIR
SIR
SIR's Avatar
.....this took all of about 1-hr total....
Old 12-01-2006, 12:56 AM   #25
leftcoast66
That's a good lookin notch. I'm hoping to run a full monster notch with a 5 lug 78 chevy axle and then a triangulated 4 link setup rather than factory trailing arms. Should lay on the ground, and if my measurements are correct, it should lay out on some 24" wheels. It's gonna be huge, but I wanted it to be able to come within inches of laying w/ my full drag slicks on the truck. I'm hoping to go w/ a kind of drag truck crossbred w/ lowrider setup.
