Old 12-01-2006, 04:43 PM   #1
sixnine
Longtime Member
sixnine's Avatar
Eight Lug to Six Lug
I have a buddy with a 1968 C20 father/son project. They want to change the bolt pattern from an eight lug to a six lug so they can mount some late-model rims and tires that they already have. What would be the easiest/cheapest way to do this?
I've done a search and found a ton of six-lug to five-lug stuff (obviously) but nothing for eight lugs to six.
Rokcrln - "I'm a major car addict so trying to go as low buck as possible is like asking a coke head to use flower to save money."
1972 C10 Short Step -http://67-72chevytrucks.com/vboard/s...d.php?t=261405
sixnine is offline   Reply With Quote
Old 12-01-2006, 04:49 PM   #2
shaneschevys
Its always something!
shaneschevys's Avatar
Re: Eight Lug to Six Lug
It would be basicaly the same as the 6 to 5 swap. Find a 6 lug rear end & I believe the 1/2 ton & the 3/4 ton a-frames are the same just have to change the ball joints to run the 6 lug stuff.
79 p10 stepvan
72 Short Fleetside
72 Suburban
67 GMC One Ton Flatbed
64 Short Fleetside
57 Chevy 2DR Hard Top
57 Chevy 2dr wagon
65 f*** short fleet
63 C 60 Flatbed
Member of the patina club
shaneschevys is offline   Reply With Quote
Old 12-01-2006, 07:28 PM   #3
Aarons72s
Upper A-arm will be fine lower one will need to be replaced. The lower one has a larger diameter hole for the ball joint on the 3/4 ton. You need to get one off of a 67-70 1/2 ton. Oh and be forewarned, the newer, 99-up six lug wheels have the same bolt pattern but the center hole is a smaller diameter than the original 67-70 wheels. The center hole on the new wheels will need to be machined to the larger diameter. Or the rear axle and front hub will need to be machined down to the newer wheel center diameter. Hope this helps.
Aarons72s is offline   Reply With Quote
Old 12-01-2006, 08:11 PM   #4
Green Machine
Green Machine's Avatar
The newer stock wheels, if that is what they have, also have about 5 inch back space, they will sit inside a long way, assuming you get the hub size problem fixed.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 12-01-2006, 08:46 PM   #5
69gmctowrig
Mannn i wish i had known a couple weeks ago i would have swapped parts with you for free. truck's gone now though...
69gmctowrig is offline   Reply With Quote
