Old 11-30-2006, 12:31 AM   #1
snacob14
Air lift BAgs
Anyone had any experience with this brand of bag. I was on suicide doors and saw these were a little cheaper. Also, can someone tell me what I should pick up along with the rear bags on this purchase. All I want to be able to do is install the rear bags and raise and lower the rear in the garage. I won't be driving this project for another year or so i'm sure, but I'ld like to nail down the rear bag install and have some control over the ride height as I seet up the front. I konw I'll need two bags, but then what else. I plan on using the same location as the rear coils for my lift and I'll fabricatte my own notch.
snacob14 is offline   Reply With Quote
Old 11-30-2006, 01:58 AM   #2
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
Re: Air lift BAgs
airlift bags suck... I will try and post the ones I purchased. They overextend easily and come apart and thats dangerous for a vehicle you drive..
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 11-30-2006, 10:30 AM   #3
thekid54
Re: Air lift BAgs
Can't help you on the Air Lift bags, never used them. I myself prefer Slam Specialties, but Firestones are good aswell. You will also need to order some air line, a fitting for each bag, a tee fitting, and a schrader valve that will fit the tee fitting. This would be the cheapest and easiest way to adjust the height of the rear. Just use your shop air to fill the bags like you would your tires, and let air out to bring it down.
thekid54 is offline   Reply With Quote
Old 11-30-2006, 11:10 AM   #4
project76
project76's Avatar
Re: Air lift BAgs
I also recommend the slam specialties bags. RE7's are great bags.
Brandon
project 67 swb bagged on 20" Coddingtons
project76 is offline   Reply With Quote
Old 11-30-2006, 01:23 PM   #5
pharcyde05
pharcyde05's Avatar
Re: Air lift BAgs
yea what the first guy seid i had a friend that was all excited when they came out he loved them at first but after a few months they would come apart i had to go help him o the side of the road 3 times then he ditched them and went to slams
i have 3 baged trucks and all i will ever run is slams
if you want to go cheaper and arnt going to be running more than 150 psi witc you should never need that much in the rear i would go with firestones i had a set on the rear of a 2000 silverado for 5 yrs but i never put more that 120 psi in them
pharcyde05 is offline   Reply With Quote
Old 11-30-2006, 06:55 PM   #6
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Re: Air lift BAgs
'nother vote for slams here
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 11-30-2006, 09:31 PM   #7
snacob14
Re: Air lift BAgs
so you're saying for five bucks more, a better investment would be the slam specialties RE200's that suicide has. The firestones are 69 and the slams are 75. Whats the reasoning for that, is it the higher psi rating. also, will these mount the same as the firestones in the back. They aren't wider from what I have read are they.
Old 11-30-2006, 11:31 PM   #8
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: Air lift BAgs
I've had air lift 2b7 extreme bags for 4 years now never had a problem
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 12-01-2006, 12:12 AM   #9
67Fleet
67Fleet's Avatar
Re: Air lift BAgs
Yes, a better investment. You'll get a stronger bag, with internal bumpstops, they ride awesome, and will last a lot longer. And they don't balloon as much as stones or airlift bags.
-Bret
Old 12-01-2006, 01:05 AM   #10
jimmydean
jimmydean's Avatar
Re: Air lift BAgs
I'm really happy with the way my Slams work. I would say they are work a few bucks more.
jimmydean is offline   Reply With Quote
Old 12-03-2006, 09:21 PM   #11
snacob14
Re: Air lift BAgs
Now, I would need the 7 inch ones correct
Old 12-03-2006, 11:27 PM   #12
steveo10
steveo10's Avatar
Re: Air lift BAgs
i have airlift and they seem to be working fine so far. i might change to the slams after a little bit just cause i like the intrenal bumpstop and the metal caps.
steveo10 is offline   Reply With Quote
