How much lift do you get with firestone 2600?
I am figuring out the front suspension setup ( 71 C20 longbed) and I need to know roughly how many inchs will the front lift with Firestone 2600 bags, I am running a small block (All stock so far) with th400 trans. I know it varies with air pressure and weight but thats why I am asking rough guess from others experience
Thanks |
Re: How much lift do you get with firestone 2600?
bout 7 or so inches at max, usually mine only goes up about 4 or 5 inches at most since it doesn't need to go much more on my truck.
Approx. 6"-7" is what I get from 2,500 lb. Firestone's on the front.
On the fast track to nowhere..
I had 2600s on my 88 and they lifted from the frame on the ground to the upper control arms against the frame on 150lbs of nitrogen.
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
heres mine wit firestone 2,600 now i have installed slams if u want more lift go with slams.
1969 chevy bagged, fully shaved still UnDeRcOnStRuCtIoN Last edited by N2TRUX; 12-14-2006 at 12:28 AM. |
you get 6inches with firestone and 8 with slams best thing is that slam are nonballoning but firestone are
this came from Suspension Connection
Air Spring Replacement - Firestone Air Bags: Double Convoluted Air Spring - Ride Height 5"-6.5" / Max. Diameter 8" / 3/8 NPT Air Inlet - EACH Firestone air springs and accessories are the preferred choice of the street vehicle enthusiast who demands quality and ride performance. With highly engineered air springs and components. Ride height 5.0" - 6.50" Max Diameter 8" 3/8 NPT Air inlet 2500 lbs at 100 PSI
http://www.cardomain.com/ride/2461088 |
