Hei install question
OK on my 67 its got a 350 in it with points distributor. Ive installed a hei. There are 3 wires under the dash going to a silver box. Pink,green, and black. The pink wire went to the + side of the coil. What wire down at that box do i need? Also do i not use that box at all? The only wires i see coming from the fuseblock is the green and the black wire.
River life......
Re: Hei install question
http://67-72chevytrucks.com/vboard/s...ht=hei+upgrade
http://67-72chevytrucks.com/vboard/s...ad.php?t=17403 http://67-72chevytrucks.com/vboard/s...ad.php?t=13698
#3 | |
Thanks but that doesnt help me. |
Got a pic of the silver box? Something aftermarket?
After my family goes to bed Im headed back out to do the wiring. Im just going to run a wire from an open spade in the fusebox to the dist. I will post back later and hope i can tell everyone i got it running.
18 Till I Die
Run a good Power wire from the fusebox so you have 12v in the start and run position. 0v in the off position. Plug tach wire in if you have one... next to the 12v on the distributer. Lose the silver box. Should fire...
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... ![]() |
#7 | |
Thats what I did, 10Ga with a 30AMP inline fuse. Never had a problem.
Just make sure it has juice in the start & run position & you will be fine. Thats how I did mine...
its all about the +6 inches
is that box close to the fuse box?
Sounds like the horn relay, but why it was wired to the coil... ![]() |
![]() Join Date: Sep 2005
Horn relay--pink wire is hot all the time-green wire goes to horns-black wire to horn button.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
Yes it was the horn relay.
I flooded it, plus i cant check for spark right now. Wife is asleep. I guess im gonna have to have her help in the morning before she leaves for work. |
71 Chevy
I have always used the unfused terminal right off the fuse box. It is wired to turn off with the key. You can also put a fuse in the wire that you run to the distributor. I think that is the easiest way to hook up an HEI in a points vehicle.
71 C10 72 C20 62 Chevy II 2DR HT |
hey you have a HONKING HEI
![]() welcome to the board and where you at in il Last edited by rage'nrat638; 12-12-2006 at 12:11 AM. |
#15 |
Chief Honcho In Charge
I just did my HEI upgrade last weekend. I feel like I have a brand new truck.
1992 1500 4x4 Shortbed 1984 Ford F250 Supercab Longbed 6.9L Diesel 1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C 1971 VW SuperBeetle 1960 Wife 1984 Son 1986 Son 1989 Son Previous Trucks 1967 C10 SWB (1980-1981) 1971 C10 LWB (1998-2004) |
#16 |
OK so far it wants fire but it backfired out the exhaust. Is it 180 out? I just stopped there till i get a reply.
Thanks for the help. |
#17 |
Dave's not here, man
Have you re-checked your firing order? 1 8 4 3 6 5 7 2 in a clockwise rotation
I would check that first. Also, is #1 at TDC? If you're having trouble finding TDC you can pulled the driver's side valve cover and make sure both valves are closed on #1. Keep us posted.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
#18 |
ok i checked with a volt meter. I have 12 volts at the wire at the dist with ignition on. I have it at TDC with #1 valves closed. I am getting gas. I have the firing order correct Ive checked that 4 times to be sure. I have the rotor button facing #5 cylinder. if i remember right thats the way i have done it years ago.
I am still getting small backfires out the carb. I am at a loss right now. |
#19 |
The rotor has to face no.1 at TDC
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
#20 |
#21 | |
It still wont run. Im going to change to another hei i have. I hope it works this time. |
#22 |
![]() Join Date: Oct 2006
You can also go to NAPA and get the factory style fuse block connectors(spade type expand and lock into place),take off the firewall connector remove the resistor wire and connector and replace it with the new 12/10 gage wire to the HEI and your done.Plus it gets rid of the EXTRA wires!(resistor and yellow)
#23 |
Guys i have almost 2 days in doing this. I cant get it to run. im at a loss and no idea what to do. Ive got the other hei installed and still NOTHING.
#24 |
i put the motor at TDC took the driver valve cover off. Both #1 valves are closed. I set the dist in to where the rotor is pointing to the number 1 plug. I had my wife turn the motor over this morning to make sure i had spark and i do. I am getting gas. I checked with a volt meter at the dist to make sure i was getting 12 volts and i am. I dont know what to do..... I can take pics of every stage if need be...
#25 |
ok, please forgive me if this sounds like i am treating you like an idiot... but I have seen this happen more than once.
You say when the piston is at TDC on cylinder #1 (dvr front plug) that the rotor is pointing to #1.... here's where I hope you don't get insulted... is it pointing to the #1 cylinder...as in on the engine... or the terminal that holds the plug wire that runs to the #1 cylinder. I've seen it happen more than once. |
