Fuel Tank Switch Troubleshooting
Hey all, I'm new to the Old School pickup thing. I just got an 81 C-10, which came factory equipped with dual fuel tanks.
I've been scouring the net for 2 days now to find out how the dual tank switching system works, but I have found very little on it. My problem is that mine doesn't work. I plan on testing the switch with a multimeter to see if it works, but in the mean time I could use a little input on how to troubleshoot this system. It seems like they left it out of my Hayes manual.... Any help or sources of information is greatly appreciated. ![]() |
#2 | |
Until Seventy Times Seven
Re: Fuel Tank Switch Troubleshooting
Your problem may not lie with the switch, but mayby with the fuel tank valve selector. Here's a few links dealing with the fuel valve: http://67-72chevytrucks.com/vboard/s...d.php?t=213992 http://67-72chevytrucks.com/vboard/s...d.php?t=207287 http://67-72chevytrucks.com/vboard/s...d.php?t=180143 If it is the switch, you can check the operation of it by checking its' four terminals. The black wire supplies the ground and the pink wire supplies the +12V source to the fuel tank selector valve (through the switch). With the position of the switch selected for the right tank, the light green wire is ground and the dark green wire is +12V. With the position of the switch selected for the left tank, the light green wire is +12V and the dark green wire is ground. These two wires feed the fuel tank selector valve and metering swtich.
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
Here is a link to a problem I had with the switch valve itself.
http://67-72chevytrucks.com/vboard/s...d.php?t=201901 The link will show you the inside of the valve if you are interested.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
Thanks for the info!
It turns out that it was a loose wire behind the dash... I have devloped a new hatred of messy wiring, so thats my new task this week. Merry Christmas!! |
#5 | |
7000 #'s of american IRON
but it probably was at some point, so mute deal there. |
