Old 05-31-2006, 01:21 PM   #1
HotRod73
HotRod73's Avatar
Help! Oil Leak..
I have a 73 Chevy C20 3/4 ton pickup. Has a 350 motor and is leaking. Its leaking by the flywheel cover, it has a hole in the bottom i guess to let oil drain, well its coming from there... its not leaking from behind my block i looked at the intake etc and no oil leak, its got to either be my oil pan gasket at the back, or a rear main seal, or both or i was told something about oil sending unit or something could be possibility? it isnt leaking a whole lot but its noticable on the ground and smells when truck is hot... what do you think it could be? i know my oil pan is leaking a tiny tiny bit around a few of my bolts could this be it? i havent taken my flywheel cover off to inspect but thats were the oil is dripping from.... if its my oil pan gasket, will i have to lift the motor to take the pan out or will it slide out without messing with lifting motor?
HotRod73 is offline   Reply With Quote
Old 05-31-2006, 04:42 PM   #2
Nolowrider
Nolowrider's Avatar
Re: Help! Oil Leak..
Usally if it is leaking from the flexplate cover it is the rear main seal. I guess it could be the oil pan gasket, but very doubtful. I would place my money on the main seal.
Nolowrider is offline   Reply With Quote
Old 05-31-2006, 04:43 PM   #3
jberkeley
86 chevy k-10
from experience, it sounds like rear main seal.. go around the oil pan and tighten all the bolts.. that might stop some of the leaks... this might fix the main leak..if it isn't the rear main, some chevys you have to lift the engine to drop the oil pan..i have a 4x4,mine just pulls off...good luck
jberkeley is offline   Reply With Quote
Old 05-31-2006, 06:55 PM   #4
HotRod73
HotRod73's Avatar
is rear main hard fix? does this require disassembling the whole motor?... is it something i should fix or find a replacement engine? this motor only has 91k original miles and runs like a top just leaks a little... shoot it can be cold or hot and ill go out and start it, most older vehicles i see they gotta crank it... i turn my key and it barely cranks and fires up just like a new car...of course i still got points i am planning on changin to hei soon...
Old 06-01-2006, 06:26 AM   #5
jberkeley
86 chevy k-10
rear main seal can be fixed, if it runs that good keep it, just have the seal replaced.. older engines come with a two piece seal, the newer comes with a one piece.. i can't remember the year they changed,,,,
Old 06-01-2006, 09:12 AM   #6
Slonaker
Insert Witty Text Here
Slonaker's Avatar
The change to the one piece rear main seal was in 1986.
Here is swervin's instructions for changing the seal:
http://www.73-87.com/7387garage/drivetrain/rearseal.htm
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 06-02-2006, 11:48 PM   #7
Chevrolet4x4s
Chevrolet4x4s's Avatar
My money is also on rear main seal
Shane
1993 K1500 350 5 speed
1985 K10 Silverado Vortec 406 5 speed (in body shop)
"I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been
No, I ain't broke I'm just broken in"
1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle )
Member#20327
Chevrolet4x4s is offline   Reply With Quote
Old 06-06-2006, 03:39 PM   #8
BigDan3131
BigDan3131's Avatar
And yes you have to pull the motor to change it. That and they have to pull the crank to do it as the seal fits around the crank to seal it.
BigDan3131 is offline   Reply With Quote
Old 06-06-2006, 05:18 PM   #9
Slonaker
Slonaker's Avatar
I have never replaced one, but I am pretty sure you don't have to pull the crankshaft to do it...
Slonaker
Stock '01 Silverado
Old 06-06-2006, 11:45 PM   #10
Chevrolet4x4s
?????Are we talking about a 1 piece seal or 2 piece? also If you can get the pan off i see no need to pull engine.
$.02
Shane
Member#20327
Old 06-06-2006, 03:46 PM   #11
larry may
Be sure to check the cam plug while you are in there.It could be leaking. Mine did .
larry may is offline   Reply With Quote
Old 06-06-2006, 06:27 PM   #12
Nolowrider
Nolowrider's Avatar
Larry, What is a cam plug? Never heard that before.
I have replaced the rear seal without pulling the engine or the crank. As long as you can get the oil pann off you are good to go.
Old 06-27-2006, 01:35 PM   #13
HotRod73
HotRod73's Avatar
well here is another thing, when i let the truck sit a few days non running doesnt seem to leak, only when i got the engine for a while then ill come out few hours later and see a little on the ground not saying it doesnt leak when non running but seems to only do it when its running for while
Old 06-28-2006, 11:31 AM   #14
boatpuller
boatpuller's Avatar
mine does the same thing...only get about a drip the size of a quarter.only drips after running it.looks like the rear main,but ends up drippin off the starter.i just put down cardboard on the garage floor,till it gets real bad.
boatpuller is offline   Reply With Quote
Old 06-28-2006, 02:17 PM   #15
Nolowrider
Nolowrider's Avatar
When the engine is not running there is no oil pressure and the oil is not being circulated within the engine.
Old 06-29-2006, 02:20 PM   #16
HotRod73
HotRod73's Avatar
okay so it is the rear main seal?
Old 06-29-2006, 08:19 PM   #17
89 crew
Are you sure it is engine oil? I have had one converter break the welds and leak. I have also had the converter seal leak. Most likely it is the rear main seal. If it is yes the engine will have to be lifted to get the pan off. It won't clear the crossmember. and watch the distributer when you lift it! They like to get into the firewall. Are you sure the smell is comming from there? Most of the time on the 70's 350's it is the rocker arm cover gaskets leaking that stinks things up.
89 crew is offline   Reply With Quote
Old 06-30-2006, 12:45 AM   #18
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Originally Posted by 89 crew
... Most likely it is the rear main seal. If it is yes the engine will have to be lifted to get the pan off. It won't clear the crossmember...
89crew,
I didn't have to lift the engine when I removed the oil pan on my truck. I've taken it off a couple of time. If you crank the engine so that the crankshaft is a position so that you have clearance for the oil pan to clear the crossmember when you slide it out. You do have to remove the bell housing first.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 06-29-2006, 11:48 PM   #19
HotRod73
HotRod73's Avatar
its engine oil... the smell is burnt oil burning from when it hits my exhaust... converter? as in catylic converter? if so i dont have converter im almost certain now its rear main failing
Old 06-30-2006, 12:15 AM   #20
89 crew
What is a 73 doing with a converter? I didn't think they were factory till 75-76. As long as you have decient oil pressure the seal is the only thing failing. If the oil pressure has dropped, I would replace the oil pump and probably rods and mains since you are going to have it open. They shouldn't be trashed after 91k, but they will have some wear.
Old 06-30-2006, 02:59 AM   #21
magnethead
7000 #'s of american IRON
magnethead's Avatar
reffering to torque convertor....
magnethead is offline   Reply With Quote
Old 06-30-2006, 01:28 AM   #22
89 crew
I have a 76 c20 and the engine had to be lifted a few inches to clear. Mine is a 4 bolt main, don't know if that makes a difference but there wasn't any way for mine to come out without lifting.
Old 06-30-2006, 02:36 PM   #23
HotRod73
HotRod73's Avatar
oh yeah its black so its oil not tranny fluid..
Old 06-30-2006, 02:38 PM   #24
HotRod73
HotRod73's Avatar
my oil pressure needle is right in the middle
Old 12-23-2006, 10:28 PM   #25
79Silv4x4
Workaholic
79Silv4x4's Avatar
Ever seen/had a bad gauge?
79Silv4x4 is offline   Reply With Quote
