Old 01-13-2007, 01:41 PM   #1
gotmud
gotmud's Avatar
how to manually spin the engine
I need to spin my engine over. I have tried the following:
- remote starter switch - it buzzes but doesnt turn the engine
- bolts on the harmonic balancer - they seem to tighten more and I am afraid I will strip them out.
- tightened the belts and tried to spin the alternator - the belt just spings around
Any other ideas or tricks/tips form someone more experienced than I????
Glenn
Cumming, Ga
(68 C/10 Fleetside LWB 307
(64 C/10 Fleetside Shorty Custom 350, with 73 donor parts aplenty)
(2001 Porsche Boxster S - 168 MPH of fun)
(2005 Chevy Avalanche Z71 1500)
gotmud is offline   Reply With Quote
Old 01-13-2007, 01:46 PM   #2
cdowns
cdowns's Avatar
Re: how to manually spin the engine
did you take the sparkplugs out??
Old 01-13-2007, 01:53 PM   #3
gotmud
gotmud's Avatar
yes
Glenn
Cumming, Ga
Old 01-13-2007, 01:57 PM   #4
kwmech
How about a large screwdriver on the flywheel
Old 01-13-2007, 01:59 PM   #5
gotmud
gotmud's Avatar
Could be...but I was hoping for some majic to keep me top side.....Im trying to find TDC for I can make sure my dizzy is in right.
Glenn
Cumming, Ga
Old 01-13-2007, 02:04 PM   #6
Sandemonium
Proud owner of a 55.1 AD
Sandemonium's Avatar
Have you tried using a tool to rotate the flywheel. Sometimes you can get more leverage on the flywheel that on the harmonic balancer bolt.
Of course you would want to remove the spark plugs before attempting this.
Also, Is this a manual or automatic transmission? If manual is the vehcle in gear?
Just some thoughts......
Sandemonium is offline   Reply With Quote
Old 01-13-2007, 02:08 PM   #7
gotmud
gotmud's Avatar
The engine is in the truck. Its an auto tranny in park. The plugs are removed. Headers are on.
Glenn
Cumming, Ga
Old 01-13-2007, 02:33 PM   #8
cdowns
cdowns's Avatar
put bolts(3-4inch long) in balancer then use a long lever(prybar) between the bolts
Old 01-13-2007, 02:40 PM   #9
Elsie72
Chinook Arch
Elsie72's Avatar
Deep socket and breaker bar on the nose of the crankshaft? Or is that just for Fords?
1972 GMC 1500 Custom - Bought used by Grandpa in '74, currently back on the road after a long hiatus.
Elsie's truck
2.5" dual exhaust with Hooker Aero Chambers
Holley 670 Street Avenger Edelbrock Performer RPM on GMPP 290HP 350
ECE drop 3.5/5
Elsie72 is offline   Reply With Quote
Old 01-13-2007, 04:07 PM   #10
krue
Designated A-hole!
krue's Avatar
You run the risk of stripping out the threads in the crank nose doing it like that.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 01-13-2007, 04:16 PM   #11
BarryB
BarryB's Avatar
They make a socket that goes on the end of the crankshaft for turning the motor over.(summit racing) But that would mean you would have to pull off the harmonic balancer. Is it a new rebuilt motor?? Seems there might be something wrong if you can't turn it over by the other methods.Even a fresh motor should spin with the crank bolt. Hope you figure it out.
BarryB is offline   Reply With Quote
Old 01-13-2007, 04:20 PM   #12
gotmud
gotmud's Avatar
Heres what I did...
- Took an old fan belt
- jamed it up the end of a piece of black pipe
- secured the end in the pipe with a screwdriver
- wrapped the protruding belt around the crank pully
- bingo....spins like a champ
must have been old and creapy like me....
Glenn
Cumming, Ga
Old 01-13-2007, 07:23 PM   #13
krue
Designated A-hole!
krue's Avatar
Sounds like a homemade strap wrench to me.
www.daveramsey.com
Old 01-13-2007, 10:17 PM   #14
PumiceMan
Junior Member
PumiceMan's Avatar
I've always just used a 5/8 socket and breaker bar on the balancer bolt. With the sparkplugs out, it shouldn't be too hard to turn. The torque applied doesn't seem too high - I've been able to do this and turn it counter-clockwise without loosening the harmonic balancer bolt (with a 1/2" drive ratchet to boot).
There are a couple of crankshaft snout sockets that you can use (one that's round on the outside with a 1/2" drive hole, and the other shaped like a big 6-sided nut), but these do require you to remove the balancer. I think there's also another tool that looks like part of a balancer puller, that attaches to the face of the balancer by bolting it in the three pulley holes, but then you've got to pull the crankshaft pulley to use it (which means also getting the balancer bolt out). cdowns's idea above would work without having to remove the center bolt.
69 GMC Sierra 1500 Custom
68 Camaro SS
18 GMC Sierra SLT
Living the dream
PumiceMan is offline   Reply With Quote
Old 01-13-2007, 10:27 PM   #15
hvychve
To The Levy
hvychve's Avatar
manualy turning an engine shouldnt take much effort, the 5/8" socket on the front crank bolt shouldnt require enought turning torque that it might break, this would indicate to me that there is somthing wrong, remove the flex plate cover and pry the teeth of the flywheel against the transmission case , if you cant turn the engine at all , sounds like engine is locked up , either threw a rod or if its a new engine and wasnt lubed thouroughly enough during instalation, you can open the throttle plates on the carb and dump about half a quart of oil straight down the throat, this will allow the oil to seep down onto the cylinders and hopefully loosen up a tight new rebuild that maybe was lightly lubed during rebuildd , if this is not the case. remove the engine and rebuild it. or find the cause of why its locked up. hope this helps.
hvychve is offline   Reply With Quote
Old 01-13-2007, 10:28 PM   #16
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Usually you can just grab on the balancer and turn the motor over by hand with the plugs out.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
