Old 01-27-2007, 12:12 AM   #1
isenegger
straight axle on 76 2wd truck.
how hard is it to put a straight axle under my 76. i do not need the 4x4 i just want to lift it with like 8" springs and make it big. i have a jeep to play around in. i just want it big. what all is involved in putting a 10 bolt or so under the front
isenegger is offline   Reply With Quote
Old 01-27-2007, 02:13 AM   #2
1969 GMC
1969 GMC's Avatar
Re: straight axle on 76 2wd truck.
they make lift kits for 2wd trucks
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 01-27-2007, 08:52 AM   #3
isenegger
probably not one for that year and not 10" or so
Old 01-27-2007, 10:16 PM   #4
Bowed
I did that years ago and it worked out good . the best that I remember it was the axle hub to hub , springs , spring plates , U bolts , 4X brackets & bushings , 4X cross mount for motor with mounts , changed the steering box and pitman arm to 4X type & added longer brake lines . I'm not sure if the 4X cross member raised the engine , seem's there was something about that whatever it was .
Bowed is offline   Reply With Quote
Old 02-04-2007, 12:43 AM   #5
isenegger
what all is involved in slinging the axle and doing to steering??
