Parting hot rod 72 Cheyenne
Well, I can't seem to sell my 72 so I'm parting it out. I'm not taking anything off until the motor sells. After that everything is fair game. I want $4000 for the motor. It has about 2000 miles if that since it was rebuilt. I have all reciepts. You can hear and drive if you want to. after the motor sells I'll price the rest of the truck parts. This is just for the motor at this time. I'll ship it but buyer will have to pay for it.
1972 Chevy Cheyenne Motor:454 .60 468 ci cast crank turned .10 .10 Shot-peened rods with ARP bolts Speed-Pro coated pistons Comp Cams 282 solid cam with Comp Cams lifters and pushrods Lunati roller thrust bushing Cloyes double roller timing chain Mini starter TCI flexplate with ARP bolts Oval port heads with hardened seats, 3 angle valve job Manley valves 2.19 and 1.88 Crane Gold roller rockers 7/16 stud Edelbrock Airgap intake Moroso Billet valve covers Full MSD ignition with 6AL box Taylor wires Demon carb Transmission: TH350 Full manual conversion B M Holeshot 3000 converter B M Megashifter B M 24,000 GVW cooler TCI line lock 1 piece driveshaft with new yoke and Spicer Ujoints Exhaust Headman coated headers 1 7/8 tube 1 chamber Flowmaster mufflers 3 inch pipe with"H" pipe and dumps in front of axle Rearend 12 bolt Richmond posi 4 series carrier 4:10 gears M/W axles Fuel system Holley fuel pump Holley regulator RCI fuel cell under bed Fram filter Goodyear Hose Braided from regulator to carb Cut-off switch for pump mounted into back-up light Suspension and brakes: 4 wheel disc with CPP rear disc kit 1972 Corvette master cylinder, new booster Master power prop valve Stainless hose upgrade New Emergency brake cables Fresh brakes up front 5 lug factory disc DJM 3 inch drop front springs Chisholm spindles Chisholm upper tubular control arms 1 ton front sway bar Rear DJM 6 inch drop springs Brother adjustable tracking arm Rebuilt front suspension Wheels and tires 15X10 rear Centerline Telstars with ET Streets 15X7 front with 245/60 tires Misc New 4 core radiator New carpet and kick panel carpet recovered seat New gauge panel AutoMeter gauges with Playback tach and shiftlight Kenwood CD with electric antenna mounted in stake pocket New cab mounts Spray in bedliner New wiring Battery relocated to bed Sir Michaels steel roll pan in rear |
