Old 04-01-2007, 12:00 AM   #1
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
1986 2wd frontend
IM working on my front end and replace anything that look or just seem bad. My truck has yet to be inspected but when i drove my truck it would pull to any which way i turned. So..
My lowed ball joint passanger side was bad and some steering arms ( aka tie rods and such) but for some reason as i look at the truck i couldnt stop and think somethink is missing under this truck. Turns out unlike my other 86 2wd it had no strut bar at all not even the bracket that are tapped to the frame.
(im using parts from my old 86 to put the strut bar on so i have better handling. This is ok right)
My other question is this why would two exact truck One being from canada with no added packages at all have a strut bar and a truck from flint mich. with the sliverado package not have a strut bar
UNderlined stuff is questions the rest in back story.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 04-01-2007, 12:04 AM   #2
Pyrotechnic
Pyrotechnic's Avatar
Re: 1986 2wd frontend
Do you mean sway bar ?
Pyrotechnic is offline   Reply With Quote
Old 04-01-2007, 12:17 AM   #3
Srubydo1986
The Crazy Machanic
yes sorry around imports to long
newest additions
Old 04-01-2007, 12:56 AM   #4
Ivan D.
glamoros piece o' lowlife
Ivan D.'s Avatar
My '79 half-ton don't have a swaybar either, think it was an option on the light-duty trucks. Oddly enough the truck handles just fine without it, in comparison my car even with its lower center of gravity and stiffer springs dives like a paddle boat in hurricane if the swaybar is disconnected - go figure...
The more I drink, the more I drink, the more I drink...
diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express
Ivan D. is offline   Reply With Quote
Old 04-01-2007, 01:22 AM   #5
BaddBusa2005
BaddBusa2005's Avatar
I added one from a 87 suburban to my 81 deluxe, what a difference
1981 Custom Deeluxe SWB 5.3/4L60e 3.73 and Auburn. Mustang Dyno 265hp/258tq
BaddBusa2005 is offline   Reply With Quote
Old 04-01-2007, 01:39 AM   #6
Ivan D.
Ivan D.'s Avatar
the brackets that hold the sway bar to the frame are normally riveted to the frame, and those are some massive size rivets too - rivets can be replaced with bolts and nuts, however how did you take the brackets off yer donor truck?
Old 04-01-2007, 01:43 AM   #7
BaddBusa2005
We used a plasma to cut the heads off of the rivets, then i used grade 8 harware to mount them to the frame
Old 04-01-2007, 11:02 AM   #8
Srubydo1986
The Crazy Machanic
for me im going to grind the rivets out dont have a plasm cutter. one of these day i plane to have one along with a setling torch.
Well see if putting one make the truck better. IM used to my old 86 driving like a car corning a 60 in a long bed witha 4 sp not a problem for a 35 mph corner. Granit I most likely wont do that with this truck only cause id like to keep it nice forever plus repainting would be cheaper cause there would be no big dents/rust.
newest additions
Old 04-01-2007, 05:20 PM   #9
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I went through this a few years ago, and just bought the swaybar brackets from the dealer. I don't have a parts truck, so I was going to have to chisel them off with a BFH and a chisel at the junkyard. That sounded like a little too much fun for me.
They weren't real expensive. I just bolted them in. It made a huge difference in the handling. Now I want to get a bigger one off a 3/4 or 1 ton.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 04-01-2007, 05:41 PM   #10
BaddBusa2005
the one i pulled off of the burb was a bit bigger that the one that would have been on the truck
Old 04-01-2007, 09:43 PM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
That is correct. The sway bar from a Burb, or C-20 is larger and requires larger bushing.
The sway bar bracket "stands" are not really necessary. The bushing clamps can be bolted directly to the frame.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
