Old 04-13-2007, 02:26 PM   #1
CPNE
Resident Curmudgeon
CPNE's Avatar
Guage cluster and speedometer cable questions
I can take apart 67-72 gauge cluster with my eyes closed but have never messed with the 73-87 variety. These questions pertain specifically to an 81 cluster with oil pressure, temp, and volt gauges. No tach.
I have a squeeky speedo cable and I want to lubrucate or replace it.
Questions:
1. It's difficult at best to reach in behind the cluster. Is it best to remove the cluster to gain access to wherer the speedo cable attaches? If not, what's the best way to access? If so, any tips on best way to pull cluster from front? (see question 3)
2. Does the speedo cable have a threaded attachment or is it clipped on? How do I detach from back of speedo?
3. If I do have to pull the cluster out from the front, what all is attached behind it? On 67-72, the oil pressure has a separate hard line to it. Is the 73-up oil guage electronic? Other than the possibility of a separate oil line, is there just a wiring harness to detach?
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
