Old 04-08-2007, 04:28 PM   #1
tim123104
what gears to run?
in my blazer i have a 350, th350 with 7" of lift. iam about to put 38.5x15x15. im thinking 4.56, but not sure if this is too much. also how hard is it to change ball joints on the front axel? thanks for any input.
tim123104 is offline   Reply With Quote
Old 04-08-2007, 04:33 PM   #2
1969k10stepside
Re: what gears to run?
What will it be used for?Going on the highway much?If its not a road use blazer then 4:56s will be fine.Ball joints....some come off easy,some dont.I had to torch mine off.Then had to weld up what I destroyed in the process
1969k10stepside is offline   Reply With Quote
Old 04-08-2007, 06:31 PM   #3
Duro5341
Duro5341's Avatar
The ball joints on the axle sometimes come out easy....but they are time consuming to do. I would suggest changing the u-joint, and wheel bearings at the same time, as you already have it pulled apart
As for gears Personally I like the 3.73's, and 4.11's.....but I am used to 31-33" tires. You have to decide what your going to be doing with the truck....higher gears will kill you highway milage, but it'll have lots of brute torque off the line, and for climbing
Duro
-1986 K10 LWB, 350 HD,TH400
3.08, 30 spline 10 bolt, with an Auburn Posi, 31" tires
All original, second owner truck
-1979 Monte Carlo, 350, 200r4, 3.73 posi
-1987 GT T-top Mustang - slow moving project
Duro5341 is offline   Reply With Quote
Old 04-11-2007, 06:35 AM   #4
vtblazer
vtblazer's Avatar
I'm running 5:13's with 40" tires and it's still a pig in high range.
Find a gear ratio chart that shows tire size vs. RPM vs. speed and then figure out your 'best case' scenario from there.
Usage is everything, decide where and how it's going to be used.
It's going to be a compromise at best anyway, cause without a doubler/Atlas or something similar to drop your ratio way down, wheeling it with 38.5's and the th-350 is going to be tough.
Although, with enough HP, running the mud is a whole different story.
vtblazer is offline   Reply With Quote
