Texas Big Wig
Slam bump ?
I plan to run slam bags & was wondering if I should run an external bump stop, beings how they have an internal ?
Re: Slam bump ?
The RE7s are a good choice. They do have an internal stop but it is always recommended to run an external bumpstop.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
A guy with a truck
Re: Slam bump ?
Yep. x2
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 04-17-2007 at 12:44 AM. |
Texas Big Wig
Re: Slam bump ?
Thanks Guys
Also, what kind of weight can a RE-7 handle (I plan to haul a trailer daily) Last edited by Spray-Bomb; 04-17-2007 at 11:16 AM. |
Re: Slam bump ?
welp i've got re8's on my duramax and they handle it fine w/ my 20' trailer on the back.
69 4wd V6 20k orig miles!! ![]() 05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored. ![]() 01 rcsb chevy 2wd 6bt cummins :devil:> build xtremediesel.com |
Texas Big Wig
Re: Slam bump ?
Hey diesel
Did you go behind your axle, in top, or on top of your spring ? Are you notched ? (My dad and I are interested in bag'n his dually, but only if we can still haul heavy loads) So do you think I should run RE-8's on the rear ? This is all the info I have found that tells what weight slams can handle RE-6 Replaces a firestone 255c or contitech 2500# bag. (Front) RE-7 Replaces a firestone 224c or contitech 2600# bag. (Rear) RE-8 Replaces a firestone 2800# bag. (Rear duallys) Last edited by Spray-Bomb; 04-17-2007 at 12:08 PM. |
Re: Slam bump ?
Ya, over on dually scene their runnin RE 8's on the back w/ RE 7's up front of their dually's.
Texas Big Wig
Re: Slam bump ?
But should I run 8's or 7's on my truck, I plan to tow my Ditch-Witch R-30 trencher nearly every day (It weighs about 4,400 lbs, plus a trailer)
Re: Slam bump ?
![]() Join Date: Aug 2005
Re: Slam bump ?
For a light duty driver you need LIGHTER bags in back then front.
Re: Slam bump ?
Texas Big Wig
Re: Slam bump ?
Is there anything wrong with just swapping bags for my coils (my truck is a 67)
#14 | |
Texas Big Wig
Re: Slam bump ?
But if I can get by with no problems on 7's I'm cool with that |
#15 |
Re: Slam bump ?
I've got the 8's in back and 7's in front.
Spray-bomb, here is Slam's site. There is more info there: http://www.slamspecialties.com/ |
#16 |
Re: Slam bump ?
