Old 04-10-2007, 09:53 PM   #1
customcamper72
front driveshaft angles?
Is anyone running a dana 60 front with a 6" lift & a 4speed/205 combo in a 68-72 K20., I'm getting ready to bolt my front 60 in and wondering if I'm going to encounter any problems with front driveshaft binding, I'm running a tuff country 6" spring lift that actually lifted my truck 3" over the old 4" lift I had in it. A friend has the same combo as me in a 78 K20 and his stock front shaft bound up because of excessive shaft angles, and he had to run a high angle front shaft, will i have the same problems? Thanks for the help.
customcamper72 is offline   Reply With Quote
Old 04-11-2007, 06:19 AM   #2
vtblazer
vtblazer's Avatar
Re: front driveshaft angles?
Not really apples to apples but I have a high pinion Dana 60 with a 6" lift.
Drivers side drop to the 203.
Angle on mine is pretty good IMO.
vtblazer is offline   Reply With Quote
Old 04-20-2007, 11:48 PM   #3
customcamper72
well i got the 60 front in and the stock driveshaft works with no binding issues.
Old 04-21-2007, 10:43 AM   #4
Good to know.I have the same set-up,but haven`t swapped the D60 in yet.Not probs with the D44.
