any better throttle cable set up?
running stock linkage on my 65 model , anybody converted to something better?
thx |
![]() Join Date: Nov 2006
Re: any better throttle cable set up?
You can use a universal pedal/throttle cable combo, just got me a lokar setup last week, w/ the floor mount eliminator pedal, and cut-to-length stainless cable.
![]() Join Date: Oct 2006
Yea lokar is a sweet set up, or go to Kragans Autozone etc and use the Specter universal cable and there throttle bracket. Cheeper then Lokar and works as good. I have used both .
I modified a setup from a 77 camaro, welded some nuts to firewall to bolt it to and had to tweak the inside rod some.
64 Panel Rebuild Pics Clutch Replacement and Borg Warner T10 Trans Rebuild 64 Panel 1/2 Ton 350cubes/400hp BorgWarner t-10 3:73 Auburn Posi |
Thanks all.........
im useing the chep autozone universal pedal/throttle cable it work pretty good
ridin big yo 5in cpp lowerin springs in back lowered 3in in front with cut springs for now 5 lug swap and disk in front 5 lug and disk in the rear with 3.23 gears mild 350/400heads 7547weiand intake 600 Edelbrock chrome block hugger headers 2 1/2 pipes in to a x pipes super 40 flows and turn downs turbo 350 with shift kit |
Junior Member
I took the pedal and cable from a 86 suburban and a throttle cable bracket from spectra, worked pretty well. the cable is too long. I would reccomend the universal cable from spectra it can be shortened.
Graham
A good friend will come bail you out of jail, but a true friend will be sitting next to you saying, "That was ****ing awesome." |
how did you mount the pedal in your cab????
