Active Member
Rear bumper brackets?
Is there a difference between Blazer rear bumper brackets and pickup rear brackets for a chrome bumper? Mine don't look like they will fit unless i modify them. Also what is the major difference between them? Are the Blazer ones longer than the ones for a truck? Pics would really help.
Mike T. Oregon 70 GMC Jimmy 4x4 70 Camaro LS1 plans in the works 71 RS/SS Camaro numbers matching 86 Chevy Silverado SWB 4x4 (454 merlin heads, 3/4 running gear upgrade, Detroit lockers front and rear) |
Active Member
Re: Rear bumper brackets?
So NOBODY KNOWS?
![]() Join Date: Apr 2000
lmc has the same part number for both....
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
I'm a poor spectator
In 71 Blazers had brackets that held the bumper to the frame, starting in 72 the frame was lengthened and the bumper bolted directly to the frame. Hope that will help you a little.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
![]() Join Date: Jan 2005
I haven't see the truck brackets to know, but the brackets under mine don't look anything like what LMC shows as the truck brackets. These look like overgrown pieces of angle iron with divots cut out where the rear body mount goes.
I'd like to know a definitive answer to this as well. One of the POs welded the brackets to the frame to work with an old ghettofied hitch setup that I cut off. I didn't get to pulling those brackets off for fear of destroying them with no change for easy (read: no fabrication) replacement.
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
SKINNY TIRES RULE!
2wd brackets are different than 4wd.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
