Old 05-26-2007, 04:23 PM   #1
Rc 415
Flat Black, & Chrome!
Rc 415's Avatar
Outer brake pad
How does the outer brake pad on each caliper connect to the caliper so as it wont wobble around or drag on the rotor?
1983 Chevy C10 Stepside Sold
http://s69.photobucket.com/albums/i76/rc_415/
Rc 415 is offline   Reply With Quote
Old 05-26-2007, 04:48 PM   #2
xtreme80
Wishin' I had more money!
xtreme80's Avatar
Re: Outer brake pad
All pads will rub on the rotor a little... that's just how they're designed. I don't remember exactly how it works on our trucks, but I believe it's just a floating pad in there.
xtreme80 is offline   Reply With Quote
Old 05-26-2007, 04:53 PM   #3
Rc 415
Rc 415's Avatar
Re: Outer brake pad
Ok cool thanks for the info, have you heard or had personal experience that the outer brake pads have a little play?
Old 05-27-2007, 02:45 PM   #4
xtreme80
xtreme80's Avatar
Re: Outer brake pad
The pads are probably gonna be fairly loose. Almost every car Ive ever done brakes on have loose pads... it's just how it's designed. I wouldn't worry about the play. As long as you can't just pull them off with your hand, you're fine, heh
Old 05-30-2007, 01:50 AM   #5
jimfulco
Re: Outer brake pad
I used to put them on straight out of the box, before I found out you were supposed to clinch down the little ears on top. They did seem to clack around a little when you first hit the brakes, but I never had any serious problems with them.
jimfulco is offline   Reply With Quote
