![]() Join Date: Apr 2005
CrewCab Frame question (1/2T vs 3/4 T)??????
I'm trying to figure out the best way to build a frame for my 4 Door CrewCab. It is currently sitting on a 3/4 Ton LWB chassis. I've purchased a completely redone SWB 1/2 Ton chassis. I see my options as:
1. Shorten the 3/4 Ton frame and transfer all the parts over from the 1/2 Ton. 2. Cut the rear clip off of the 1/2 Ton and graft it on to the 3/4 Ton and transfer the front suspension from the 1/2 T frame. 3. Cut the extended portion out of the 3/4 Ton frame, then split the 1/2 Ton frame and graft in the 3/4 Ton section. 4. Split the 1/2 Ton frame, find another donor frame for donor rails and make it match the original 3/4 ton frame (as far as where the cab mounts). I'm leaning towards #4. Any one else got any ideas? Also, why is there a difference in the 1/2 and 3/4 Ton cab mount bushings? Are the mounts the same and just the bushings different? Thanks.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
BK Built
Re: CrewCab Frame question (1/2T vs 3/4 T)??????
id say swap front crossmembers, then graft on the rear of the 1/2 ton.
Hmm I think it really depends on what you plan on doing with it. Bags, Body drop, Stock height, static drop. If it was me (and I would love to build a crew cab) I would probably use the 1/2 ton front member and build new frame from the firewall back. I would use 2x4 1/4" Box and build my Z in all at the same time. If I was not going for that extreme of a build Then I would say shorten the 3/4 ton and swap over the parts.
I would do alot of measuring on the frame though make sure it is still square and straight before you begin. Reguardless though I can't wait to see the progress and I am Jealous you have a crew cab. ![]() |
The 1/2 ton chassis already had an ECE 2/4 drop and has been completely rebuilt. That's why I'm leaning toward just lengthening it.
I am a Referee of life.
You could stretch the 1/2 ton frame.Maybe use a donor frame for shape and plate the rail then use a channel on the inside to further strengthen the frame.What type of bed do you plan on using?If it's going to be a pickup bed then a factory frame is probably easiest.If you're using a flatbed a custom frame makes since because you can design the frame and bed however you want it.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
#6 | |
If it were mine, and I was trying to achieve the same objectives, I would shorten the 3/4 ton frame and swap all the components over from the 1/2 ton frame. I think it would be easier and better to worry about only one seam in the frame-rails.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
#8 | |
The original frame looks like it was extended by adding in a section from another truck. So it has two seams also. That's another reason I'm leaning towards lengthening the 1/2T frame. It will be essentially the same as the 3/4T frame, as far as the seams go. R
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 03-21-2007 at 12:46 PM. |
I think I would do the #4 option. I myself have no experience, but have seen a few videos on stretching limos and other vehicles. What was shown was them cutting the car in half and graphing parts needed from a donor car. It was real cool to see it happen from start to finish. But what do I know, I am just a squirrel trying to get a nut.
That's just my 2 pennies. Any way you go, GOOD LUCK, and show us progress. |
Here are some pictures to help clear up my rambling:
More pics:
Since the 3/4 ton chassis has already been cut-up, take the 2wd frame and lengthen it!
Now the question is, cut the lengthened section out of the 3/4T or make my own from a scrap frame? I really don't need the 3/4T frame anymore but I hate to cut it up.
#14 | |
#15 |
UPDATE: This is what I ended up doing, post #103 and down.
http://67-72chevytrucks.com/vboard/s...=226302&page=3
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 05-27-2007 at 10:42 AM. |
