I am looking for images of the factory paint schemes. Some had just the lower portion a different color (like mine was originally) others had the bottom and behind the cab etc..
The one I am looking for is where the "off color" included the hood and the upper portion of the cab and front fender. (and that scheme may be late 70's) I have googled ever way I can think of. Any Help? |
Re: OE Paint scheme images
Here's a couple of my 79 SB that's pretty close to what you want I think...
http://render2.snapfish.com/render2/.../of=50,590,360 http://render2.snapfish.com/render2/.../of=50,590,393 Last edited by Prong; 05-29-2007 at 06:15 PM. |
Thanks Prong, thats similar...
I am looking for the one like this illustration.... |
I believe the paint job you are describing is a 1985 only scheme.
A "stripe" begins on the upper body line a few inches from the front of the front fender. The lower edge of the "stripe" is even with the upper body line and goes all the way around the truck, including across the tailgate. The upper edge is about 6" higher than the lower edge and runs parallel until it gets behind the door then it turns straight up and goes over the top of the cab. The end result is the lower 2/3 of the body is one color. The upper third of the bed, the inside of the bed and the rear of the cab are another color along with a stripe that runs to the front of the truck. The top edge of the stripe rounds down and meets with the lower edge of the stripe. I've liked that scheme especially in a silver and black combo with the red pin stripe. It would be easier to describe with a picture... ***EDIT - best I could find was on 73-87.com and its a little different than I described here.***
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) Last edited by kevinr1970; 05-30-2007 at 05:23 PM. |
PS, what is your avatar of? Looks like an under shot of someone firing a machine gun from a copter?
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
Yes, thats a scene from the Matrix when they are shooting at them in the building.
Thanks for the info. |
Gentleman Jim Driver
Like this?
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '87 C10, '87 R30, 2 '89 R3500 Flatbeds |
