Old 05-27-2007, 07:30 PM   #1
bigblock79
67 Chevy Stepside
bigblock79's Avatar
blazer 2 wd convert
how hard is it to convert a 4x4 blazer into a 2 wd
1967 Chevy stepside
1976 BIG DOOLEY 454 turbo 400 4:11
bigblock79 is offline   Reply With Quote
Old 05-27-2007, 09:32 PM   #2
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
Re: blazer 2 wd convert
A bit of work casue your going to need a part truck that2 2wd to do it. I was going to make my 2wd 86 pickup a 4wd and found it to be a bit more work then thought.
Plus iv seen some people say with pics that the 2wd frame and 4 wd frame are different in the front.
Id look for a 2wd blazer personally unless the body is that nice then find a blazer that get a bad body a swap it out.
just a thought
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 05-27-2007, 10:07 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
Do a little searching on here. There was a great post one the conversion not too long ago.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-28-2007, 03:46 AM   #4
Ivan D.
glamoros piece o' lowlife
Ivan D.'s Avatar
What kinda conversion you want - just RWD, or you want the IFS too? To me the IFS is a major main in the ass, I'd be much happier with a solid I-beam front axle. As a matter of fact I'm planning on doing that conversion some time this summer, if I can find a suitable axle - I may actually need to fabricate my own one cause I wanna run coil springs and most I-beams are made for leafs.
The more I drink, the more I drink, the more I drink...
diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express
Ivan D. is offline   Reply With Quote
Old 05-29-2007, 09:14 PM   #5
bigblock79
67 Chevy Stepside
bigblock79's Avatar
all of it
1967 Chevy stepside
Old 05-29-2007, 10:02 PM   #6
Ivan D.
Ivan D.'s Avatar
Well then I'd imagine you need the 2wd engine crossmember, seeing how everything IFS attaches to it. You should be able to use the 4wd crossmember at the front of the frame, I know it's different from the 2wd one and needs to be replaced when doing 2wd-4wd conversion, but it has to do with the front mounts for the leaf springs - you lose the leafs and the hangers, but x-member can stay.
Old 05-29-2007, 10:22 PM   #7
bigtruck81
you need to pull the entire front clip off, and the engine and trans out. you're gonna need to install a 2wd trans anyways, so just pull the motor out too while you're at it. yank the engine crossmember out, as well as the motor mount towers, and bolt the IFS crossmember in place. if you wanna do an awesome job of it, buzz the rivets out of the shackle hanger brackets and fill the hole where the bushing used to be, and buzz the front spring hanger off of the bottom of the body mount.
bigtruck81 is offline   Reply With Quote
Old 05-30-2007, 12:45 AM   #8
Slonaker
Insert Witty Text Here
Slonaker's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=168231
It was a great thread. I always wanted a 2WD Blazer...
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 05-30-2007, 11:07 PM   #9
bigblock79
67 Chevy Stepside
bigblock79's Avatar
thanks i found that thread were a took a blazer and the truck at the same time. now i have to get the blazer home
1967 Chevy stepside
Old 05-30-2007, 11:56 PM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
Slonaker
Thanks buddy. I have been meaning to look it up but keep getting side tracked...
Articles-
"Refining Sierra"
Old 05-31-2007, 01:38 PM   #11
Slonaker
Slonaker's Avatar
My Google-Fu was strong that day...
Slonaker
Stock '01 Silverado
