Old 06-13-2007, 11:26 PM   #1
pissonNOS
senior member
pissonNOS's Avatar
need some electrical help
For some reason I dont seem to be able to open the valves on my airride setup. I ahve power going to my switches, I have good grounds, I used 14 ga wire to wire the valves (was this too small?) Im really hoping its due to the fact that my battery was low at the time that I did this. battery is now on the charger If anyone has any ideas Id really appreciate it.
Jason
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 06-14-2007, 01:35 AM   #2
GREASEMONKEY72
GREASEMONKEY72's Avatar
Re: need some electrical help
check all the wires to the valves and make sure theyre all good and not burnt or anything and check all other connections cause maybe something got shorted out somewhere, thats all i cant think of right now
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 06-14-2007, 04:48 PM   #3
short step
I think u need air pressure to operate the valves
short step is offline   Reply With Quote
Old 06-14-2007, 05:41 PM   #4
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Keeping an eye on this one, hope to wire mine up at the Board meet
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 06-14-2007, 08:13 PM   #5
Shane
Shane's Avatar
he is correct. you need pressure to open as well as to keep them closed.
but you should be able to barely hear the solenoid "click" a little once power is applied regardless of whether the system is pressurized or not.
Shane is offline   Reply With Quote
Old 06-15-2007, 12:24 AM   #6
jimmydean
jimmydean's Avatar
Mine had a rather loud click when switched. The best thing to do is listen, but if all else fails, run a speaker wire to the valve straight from the battery.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 06-15-2007, 08:24 PM   #7
pissonNOS
senior member
pissonNOS's Avatar
got this figured out now apparently where it says ground you dont put the ground there makes sense hey haha. anyways got them working now
69 GMC bagged
