Busted axle shaft removal on a Dana 44?
I will pull the diff cover this weekend and see what the deal is. But the axle shaft busted on the driver side and the PO pulled the shaft out, but left the broken piece.
I read last night that if there is no locker, then a coat hanger to push it out, or a shop vac to suck it out. I have a smaller shop vac, so I don't think it will have the juice to get the chunk out. Anyone else have any tips or tricks without pulling the whole axle?
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
![]() Join Date: Mar 2003
Re: Busted axle shaft removal on a Dana 44?
A lot depends on where and how the axle broke--spline twist?---, and as you already know what type of locker the diff may have or not have.
Sofa King. We, Todd, Ed.
If its not stuck maybe a large hd magnet tool will pull it out OR you could remove the axle on the other side and drive it out with a long rod, if its just spidrer gears w/no locker.
~John 71 Blazer One Ton 65 Chevelle Station Wagon x2 59 Belair 2 Door 71 Chevy Open Road Van RV www.myspace.com/johnnywagon Last edited by johnnywagon; 05-08-2007 at 02:09 PM. |
#4 | |
I will get it on stands and pull the cover this weekend, I just wanted to get an idea of what I might be in for. Did any '71 come with something in the front stock?
What do you mean,posi?Locker?
I have seen a few K20s that had 4:56s with factory lockers.There would/should be a decal for the lockers in the cab...IIRC.I dont know if they were listed in glovebox... Last edited by 1969k10stepside; 05-08-2007 at 07:20 PM. |
jack up te other side and take the wheel off the damaged side, try to get the angle of the axle as steep as possible...???
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
I had to make a slide hammer to pull one out of a 61 cj5 on a Dana 44 rear but it was not broken just stubborn actually it was a PITA took a week to figure it out and make it and that was working on it 2 1/2 hours a day that was a beech hope it goes better for you.
is it fixed?
