Old 05-31-2007, 03:23 PM   #1
RckyMntnKng
RckyMntnKng's Avatar
How heavy is a double wall top?
Can 2 people lift it off?
71 Jimmy: D60/14BFF, 9"F/11"B Lift, 350-350-203-205, Crossover Hydro steering, Beadlocks, Tube stuff and the bottomless cooler
RckyMntnKng is offline   Reply With Quote
Old 05-31-2007, 03:48 PM   #2
pound41
Re: How heavy is a double wall top?
Back in my younger days I and One of my friends did it every summer, In my old age now 3 or 4 people would be easy. Its very heavy at the back which makes it a little awkward
pound41 is offline   Reply With Quote
Old 05-31-2007, 04:52 PM   #3
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
2 can do it, just hold it towards the hatch end or it's a flipp'n on ya
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 05-31-2007, 05:04 PM   #4
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Yes, one person can remove it with some enginuity.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 05-31-2007, 10:04 PM   #5
Doghouse
What is the actual weight?
Doghouse is offline   Reply With Quote
Old 06-09-2007, 05:54 AM   #6
old man jimmy
Yes two people can lift it of. Probably weighs in around 200 lbs. But have a little hint for you. After you get the bolts all out, slide it back on the bed rails till you can get to the last bolt hole on each side. then take a piece of angle ( I used a piece from a bed frame) and drill it to match the last set of holes. Bolt that on before you pick the top off if you don't want to crack it in the middle seam. I have a 72 that came with a double wall top when new.(I ordered it in late 71)
old man jimmy is offline   Reply With Quote
Old 06-09-2007, 09:28 AM   #7
hyde
hyde's Avatar
i would say closer to 300 plus...I just lifted mine off last week and im not alil guy but it was amazing how heavy it was. We slide it back to where half the top was off them grabbed it and moved it...
06 Crew Cab GMC[/B] on 22's
07 Duramax 4x4 Lifted Maxed Out!
1972 2WD K5. 89k miles. Soon to be bagged, LS1 and bad!
1967 Short and Wide. Soon to be an LS1 and bagged
hyde is offline   Reply With Quote
