Old 06-24-2007, 09:50 PM   #1
billsbowtie
billsbowtie's Avatar
67 chevy 1/2 ton parts truck f/s
i was going to part this truck out and keep the grille for my next project but i need to move it so here what you get .
its a swb frame but frame is bad [rust holes]
fixable cab or patches
dash bezel and matching glove box door.
swb 1 piece drive shaft. is was a 6 cyl. with 3 on the tree.
6 lug rear end non pois.
doors are bad but could use the guts out of them.
it has a non cut non a/c dash.
repairable bench seat.
incab wiring harness.
grille would be very nice driver shape after a good sand blasting.
hood may could be used not sure how it would clean up.
it has a good va. title with it.
tires will hold air to load on a trailer.
6 cyl eng towers
3 speed shifter rods.
gas pedel linkage
under hood light harness.
grille park lights
no bed
come get it for $350.00
billsbowtie is offline   Reply With Quote
Old 06-24-2007, 09:50 PM   #2
billsbowtie
Re: 67 chevy 1/2 ton parts truck f/s
Old 06-24-2007, 09:50 PM   #3
billsbowtie
Old 06-24-2007, 09:51 PM   #4
billsbowtie
Old 06-24-2007, 09:51 PM   #5
billsbowtie
Old 06-24-2007, 09:52 PM   #6
billsbowtie
Old 06-24-2007, 09:52 PM   #7
billsbowtie
Old 06-24-2007, 09:52 PM   #8
billsbowtie
Old 06-24-2007, 09:52 PM   #9
billsbowtie
Old 06-24-2007, 09:54 PM   #10
billsbowtie
Old 06-24-2007, 10:36 PM   #11
qksilver
Might be interested Bill, couple of questions.
How do the hub caps look?
Ignition switch and bezel clean and undamaged with key? matches door lock cylinders?
Core support?
Trailing arms, clean?
Title ?
When you get a chance could I get some pix?
SCJKOVACH@AOL.COM
Thanks,
qksilver is offline   Reply With Quote
Old 06-24-2007, 10:44 PM   #12
billsbowtie
steve hub caps were bad. 1 fair i think its sold. before i decide to sale it hole.
key switch sill has key i will check it out tomarrow.
core suport is bad trailing arms are bad i listed most of what can be used in the frist tread.
title is good clear va. title.
Old 06-25-2007, 11:26 AM   #13
qksilver
Thanks Bill, All I really need is the key switch assembly and the part of the dash it is mounted to. I asked about the other parts to see if it was worth me getting it. I will pass but pm me if you start to part it out .............
Steve
Old 06-25-2007, 11:27 AM   #14
jkaylor68gmc
jkaylor68gmc's Avatar
Iwould love to have that thing if I had time to come get it!
jkaylor68gmc is offline   Reply With Quote
Old 06-25-2007, 11:55 AM   #15
billsbowtie
the hub caps have been sold . these pics. was took before i sold them.
jkaylor68gmc i wish you had time to come get it to.
Old 06-25-2007, 12:39 PM   #16
billsbowtie
key switch works good and is fair to good shape. door locks are gone.
Old 06-25-2007, 05:12 PM   #17
qksilver
I am using a 68 cab on that 67 4X4 swb I am restoring, got pretty much all the correct stuff for it except the 67 key switch and a set of 67 buddy buckets.
Let me know, pm me,
Thanks,
Steve
Old 06-25-2007, 10:49 PM   #18
BCOWANWHEELS
qksilver, anything you want from bill i,ll bring it to you when i bring you that rear end. bill is my pal and i,ll help you guys out all i can.
bob
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 06-26-2007, 10:48 PM   #19
billsbowtie
anyone want it for $300.00 before i start taking it apart?
Old 06-27-2007, 01:02 AM   #20
cell
Active Member
cell's Avatar
does it have a tach?
and i'll give you ten bucks for the rear view mirror if you promise it doesn't fall out of adjustment every time you go over a bump because someone put the wrong size bolt through it and stripped the threads (stupid previous owner! grr!)
cell is offline   Reply With Quote
Old 06-27-2007, 12:55 PM   #21
billsbowtie
no tach and if i part it i will let you know about the mirror.
