Grand PooBaa Member
Rear End Destruction.
New pictures, not for the faint at heart!!! LOL
I got tired of looking for a rearend or hearing prices that match a brand new Currie rear end. After almost 2 1/2 weeks of hitting my hand with a hammer and old socket extension, using a torch to loosen, breaking a bolt removal tool making it worse on the rear end, I decided to grind and cut the borken bolt and the pin out. Luckly I have another rear end I can use that I got a couple of years ago. Enjoy. |
Re: Rear End Destruction.
Damn thats alot of work. What were you going to do?
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
I saw your first post about this, you were doing an axle swap right? Man, I was terrified when I did mine a few days after. My donor rear, a '73 or 4 did the same thing to me and had to use a punch and a BFH to get the pin out of it, when it came time to pull my 6 lug axles I was puckered up the whole time taking out that damn bolt! Glad to see you got it out! I'm doing my front disc swap from a '71 in the near future and that I hope will go much smoother. The only thing that I dred is the pressed in lower ball joint! I wish there was a way to do it ON the truck. '69 with 5 lug and front disc/rally wheels in the near future!
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
I feel your pain, in Dec I had to cut one side of my carrier in HALF so I could get to the spider gear to cut it in half since it was welded to the cross shaft. It took a few hours at the shop I work at, what a nightmare.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
#5 | |
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
What was I thinking?
that broken bolt is very common and there is a tool kit that takes it out easy i have had to do it to 3 rear ends i got mine off the snap-on truck it includes a bolt that screws in the hole that is hollow and there is a long drill bit drills right in the center and then easy out comes right for future referance but that does suck
Grand PooBaa Member
That was the problem, I drilled a hole in the broken bolt, then when I tried to remove the bolt with the bolt removal tool, it snaped in 3 pieces leaving a piece in the hole I just drilled. Could not drill that removal tool out.
#8 | |
Grand PooBaa Member
Figured working on the back suspension would be easier than the front,..........NOPE!!!! On the ball joints, I took my lower control arm to the neighborhood auto shop, they pressed mine in for 10.00 each. The hardest part of the front was grinding out the rivets on the upper ball joint. |
DAM.... Ouch!!!!
Last week swapping out a pair of six lug axles in a posi rear end, I was a bit worried about the retaining bolt after seeing your story. Mine screwed right out and the center pin slipped out so easy. Too easy compaird to your story. Sorry It didn't go better for ya!
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread |
#10 | |
Grand PooBaa Member
You know how it is, a project for yourself, 2 projects for the wife. LOL |
#11 | |
My neighbor has a 40 ton press I can use, I looked at the tool you use to do it on the truck, I can buy all new front end parts for what it costs. I'll be pulling my lower arms!
Farm Truck
![]() Join Date: Aug 2006
ouch
1969 CST/10 1984 K5 Blazer 4x4 2016 Dodge Ram 2500 4x4 Mike Jersey Village, Tx |
Grand PooBaa Member
no brain no headache
Thats funny, the pin in my 96 gmc came out with little effort
1996 GMC Sierra z71 ![]() 1970 SWB 2wd (project) ![]() Last edited by 70c10swb; 05-09-2007 at 08:59 PM. |
#15 |
two words ... holy crap
,Clint LOUD PIPES SAVE LIVES ![]() 69 C-10 short stepside 406 sbc, 02 YAMAHA WR250F, 07 SUZUKI SV650S, 81 Grand Prix 355 sbc, 81 XT 500 YAMAHA |
#16 |
There's normally a little preload on the carrier bearings but once both the carrier bearing caps are off and both the axles are out, just a pry bar (maybe two), should coax it out. Nothing else physical stands in the way of its removal.
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe |
#17 |
Grand PooBaa Member
Got the rearend back in, new axles from Summit, truck has been to the Alignment shop and everything is done. Now if I can figure out why my rearend is whinning like a bird!!! I was told that when the gears are not lined up exactly right, then whinning could happen.
Im getting my wheels powder coated black in a few weeks. My other issue, if you look at the drums, the right side drum skirt sticks out past the backing plate about a 1/4 to 1/2 inch. The left side is almost flush with the backing plate. CPP is sending me another drum. Cant seem to win. |
#18 |
I'd start with the drums to make sure they're the same. Try swapping sides with them to see if the problem moves to the other side. If so, then you'll need at least one drum, but I'd replace both to ensure even braking.
If the problem is independent of the drums, then it sounds like the new axles may not be the same length. Also, the whining rear end could be a clue. Is everything correctly spaced and adjusted inside the differential?
#19 |
GEARHEAD
Isn't that just the way things go. The cross bolt comes out with out being broken when you have a faliure like this.
I have taken a few out with a broken cross bolt and one or two similar to this also ![]() RJ22... ![]() |
#20 |
Active Member
I did the same thing in my 86 before upgrading to a 14 bolt, except mine broke in more pieces than that. Nothing like big block power and big tires to put a hurtin on parts.
Mike T. Oregon 70 GMC Jimmy 4x4 70 Camaro LS1 plans in the works 71 RS/SS Camaro numbers matching 86 Chevy Silverado SWB 4x4 (454 merlin heads, 3/4 running gear upgrade, Detroit lockers front and rear) |
#21 | |
Grand PooBaa Member
I will check the axles but from what I remember, they were the same size. Talk to a friend of mine who works on differentals (Shop is a bit away) told me that I probably have to take out a shim. One side has a thick shim while the other side has 3 that are as thick as a sheet of paper. That should fix the noise. Now I have to go and get another diff cover gasket. |
#22 | |
If you have driven this thing any kind of distance or at highway speed....you have probably killed it. Unfortunately a gasket is the least of your problems. BTW if you install the gasket dry, or glue it to the cover side, it will come off UN-damaged and be re-usable. |
#23 | |
This is worrying me a bit. Are you saying you paid no attention to keeping the carrier side shims organized when you took it apart and they may not be put back in the same place as they were before? The Ring gear needs to be positioned within a few thousandths of an inch of the factory position. It took me 4 tries and about 20 hours of work to get mine right. If you've got yours out of line far enough to be causing that brake drum clearance issue, then you've got major problems with respect to ring gear alignment. No wonder the rear end is screaming. One more question. Are you sure you put the same series carrier back into that rear end as the one you took out in pieces? No matter, suggest strongly you get your friend to come over to your place and work on it. Don't attempt to drive it over there or it'll be garbage when you get there if it isn't already.
#24 | |
Grand PooBaa Member
#25 | |
Grand PooBaa Member
