Old 07-05-2007, 12:45 PM   #1
lownfast
Gettinlow & Goinfast
bagged truck need headers that clear!! help!!
my 78 is body dropped and i heard there are some camaro headers that will fit? any one know a part # or have any suggestions? thanks in advance.
Protouring Texas built rides-
78' K5 bodied on 22's, 5.3/ 4L60E- sold-Bdydrptk5- http://67-72chevytrucks.com/vboard/s...d.php?t=358390
71' Chevelle #Bigbootyjudy 6.0 LSx, LS9 heads, Magnuson, T56 - http://ls1tech.com/forums/conversion...e-ly6-t56.html
70' Chevelle #EvilAnnie Lsx/4L80/S475 turbo-
85' C20 crew, 5.3/6L90/S475 turbo-
68' C10 5.3/4L60/Level 2 coil overs
Facebook- Protouringtexasdotcom
Instagram- @Protouringtexas
lownfast is offline   Reply With Quote
Old 07-05-2007, 01:09 PM   #2
lownfast
Re: bagged truck need headers that clear!! help!!
i have long tubes but they hang down too far. i need some thing that is a mid length or shorty header. here is a little teaser to get ya'll motivated to help. thanks
Old 07-05-2007, 01:39 PM   #3
benoit454
Chris
benoit454's Avatar
Have you tried summit racing for some shorties for a truck or mid length's?
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 07-05-2007, 02:23 PM   #4
lownfast
looked at some but no one there can say if they will work or give me some specs so i can measure it
Old 07-05-2007, 02:31 PM   #5
swb85
On a budget like Fred Sanford
swb85's Avatar
Pretty sure these will be what you're after, they're 3/4 length chevelle headers. The ebay seller is a standup group, I've purchased many things from them. I've got a set of stainless longtubes for our trucks from these guys, the quality and price can't be beat.
http://cgi.ebay.com/ebaymotors/CAMAR...33330882QQrdZ1
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 07-05-2007, 03:01 PM   #6
boatpuller
boatpuller's Avatar
i have shorties.but not bagged.what kinda measurments are you looking for? ground clearence i'm bettin.i'm about 5 in drop in front,my a arms are still the lowest point.let me know if i can measure sumpin for ya.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 07-05-2007, 03:54 PM   #7
Grande Rojo
paper or plastic?
Grande Rojo's Avatar
I just put headman shorties on my 86. They fit great and you should have plenty of room for ground clearance. I got them from summit racing.
Grande Rojo is offline   Reply With Quote
Old 07-05-2007, 04:47 PM   #8
lownfast
i need some thing that stays abover the rocker. my frame is set up level with the rocker then plated with 1/2 in.
boatpuller. see if your headers stay above your rockers??
Old 07-05-2007, 04:48 PM   #9
lownfast
do your long tubes hang below your frame?
Old 07-05-2007, 05:04 PM   #10
swb85
swb85's Avatar
Pretty sure they're above the frame, I'll check this evening and snap a pic. They tuck higher than any other longtube I've run by probably 2-3".
Old 07-05-2007, 05:55 PM   #11
benoit454
Chris
benoit454's Avatar
I don't see why ANY listed shorty or mid length headers ANYONE sells that fits your year truck with your motor, say sbc 283-400 and 73-87 1/2 ton 2wd, or whatever they have it listed as, wouldn't fit.
I mean a shorty header, most don't even come past the oil pan let alone the frame rails, you run your pipes as close to the floor as you want after that.
Chris
GIT R DONE!!!!!!
Old 07-05-2007, 06:10 PM   #12
lownfast
no one makes a shorty header specific to my application. (its all camaro headers that fit. is what i am told but the local rod shop wont give me a part number and i cant return them if they dont fit) its actually a 78 blazer, but i wasnt getting any help in the blazer forum. and i have long tubes on it now. with it being Z'ed up front 3 1/2in they are barely above the stock frame rails. now that i am body dropped they are 1 1/2in below the frame.
thanks for all the info so far !!
Old 07-05-2007, 06:38 PM   #13
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
The ones you want are 3/4 length for a Chevelle for SBC.
This is the PN for the black coated ones: WLK-85118
This is the PN for the ceramic coated ones: WLK-86118
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 07-05-2007, 08:10 PM   #14
benoit454
Chris
benoit454's Avatar
So no one makes a shorty for a fullsize truck or blazer?
Chris
GIT R DONE!!!!!!
Old 07-05-2007, 08:31 PM   #15
cochino12
It followed me home?
cochino12's Avatar
Here's a set of sanderson shorties I had on my 85
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 07-05-2007, 10:38 PM   #16
Grande Rojo
paper or plastic?
http://store.summitracing.com/partde...5&autoview=sku
Old 07-06-2007, 02:29 PM   #17
boatpuller
boatpuller's Avatar
summits got hedman elite shorties.ceramic.heavy flange,ball and socket collector.just ask for 73-87 c 10 2 wd.thats what i did.anyway ,lownfast.here's a couple of pics.the passenger side is under tranny cross.i'm not sure why the dude did it that way,but i'm sure he had a reason.he does good work,i just stuck headers on there and took it to the shop for flowmasters and custom dual.i did notch the frame on pass. side when motor torqued it rubbed header.pretty tight on that spot.,you can see it in the pic's.the one underneath shot's blurry but you get the idea.hope that helps.
Old 07-06-2007, 10:36 PM   #18
68Stepbed
68Stepbed's Avatar
I have a set of Hedman 69648 Elite shorties for my 68. They should work well with the 73-87's. I really like these headers, 3/8" flanges, ball flange collecters, and 5 yr warranty on the thermal coating.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
