Rust Buster
New Chassis for the 65
Here is the stripped down new home for the 65 shop truck. Wally world moved to a new location and lost my photos. They called me the other day and said they found them at the new store. Here are the pics a few of you asked to see. It is an 84 g30 chassis with PS/PB/ A/C and 49,000 original miles. I will cut the ends off the radaitor support and weld the ends off the 65 support on to it and work back from there. Please excuse the mess. I stripped it next to my steel pile to save time double moving everything. Jerry
1961 crewcab
Re: New Chassis for the 65
so was that some sort of van? I thought they were unibody?
Rust Buster
1ton cube van had a 14ft box on it. The cab part was welded to the frame, but an air hammer 3 knuckles and a lot of cussing got it off the frame.
Tot Roddin'
I'm interested to see how this is going to turn out....
![]() Good luck with the project!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
Rust Buster
I used a 1ton box van chassis and put a 79 chev cab and flatbed on about 10 years ago my biggest problem was conecting the gearbox to the column.If i remember right we used the 79 chev gearbox and heated and turned the end that hooked to the pitman arm. Good luck.
