Old 07-27-2007, 07:48 PM   #1
Merl4
Front Brake Saddle
I just found a cheap 79 van. It has front disk brakes. I would like to know if someone has tried to exchange the brake saddle with a 1968 C10. It appears to be not much different that the 68. I believe you can exchange the 73-87 easily, but not sure about the van.
Need help answering this question.
Thank you,
Merl c Root
Merl4 is offline   Reply With Quote
Old 07-27-2007, 09:08 PM   #2
crazy longhorn
Fabricate till you "puke"
Re: Front Brake Saddle
I think you can use the spindles/rotors/calipers(with the proper ball joints), but the width is different on the van, so the saddle & steer linkage,& a arms are not useable. Maybe someone can add to this.... L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
