![]() Join Date: Jan 2011
Doooeeesn't quite look right
So i'm doing a frame off and was looking at the front end, and something looks a little off, but i'm not sure what to replace. Help me out here guys.
#2 | ||
"I ain't nobody, dork."
Re: Doooeeesn't quite look right
Are you concerned with the control arm sitting on the spring "cup"? With it suspended off the ground the it will look wonky. Set it on the ground and it will move up off of the cup. If those are lowering springs they will change the caster and/or camber.
Gary
no drop springs, looking forward it just looks like the drivers side is turned in way more than the other. Almost like somethings bent.
![]() Join Date: Jun 2002
As you put weight on the frame the tires won't be splayed out as much. Do you have the upper a-arm shims installed? It looks fine to me...
Personally, I'd get it good enough to drive then take it to an alignment shop. Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
So once I get the cab and engine back on it should straighten up?
#6 | ||
It will get closer to looking right as weight is added back to the frame (engine, transmission, cab and body).
Gary
Maybe you are missing a bump stop.
Mine looks the same when jacked up.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
![]() Join Date: Nov 2004
Yeah, it looks like the bump stomps might be missing, and about 3,500 lbs of truck...
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
